Carrier Comfort Pro Apu
Discussion in 'Ask An Owner Operator' started by BigRed40, Sep 24, 2024.
  1. BigRed40
    BigRed40 Bobtail Member
    Sep 24, 2024
    6
    Thanks Received:
    5
    Apu initially tripped. I reset breaker. AC now does not come on. Can't change it at display. HVAC says off. 20 amp fuse on back panel under cover of apu is fine. AC blower not working. AC fan on outside not working. Fridge also has defrosted. Fridge started defrosting when Apu tripped. Microwave not working but all outlets work. Apu starts and charges batteries but can't turn on AC at display. Just bought multimeter a few mins ago. Are there any other fuses I need to check? Not sure how to use multimeter correctly and/or how to check voltage. Of course I'm no electrician and I don't want to do something dumb. Any help will be grateful. All belts are fine. All plugs are right I'm assuming.
  2. mitrucker
    mitrucker Road Train Member
    Dec 15, 2010
    5,500
    Thanks Received:
    10,395
    Lapeer, MI
    These Carrier APU’s are garbage. Mine has worked properly for about three weeks in the past year. Glad I can idle my company truck.
  3. BigRed40
    Sep 24, 2024
    6
    Thanks Received:
    5
    Trying to figure it out so I don't have to go to carrier and get rxped
  4. JonJon78
    JonJon78 Road Train Member
    Jul 1, 2018
    7,246
    Thanks Received:
    43,282
    I have a Dynasys so might be a little different but, at the batteries should be another fuse where the power wire for APU is. Really shouldn't need a volt meter to check that, just open the holder and see if the fuse is fried.
    ducnut Thanks this.
  5. BigRed40
    Sep 24, 2024
    6
    Thanks Received:
    5
    Thx. Didn't think about that.
    JonJon78 Thanks this.
  6. Gridaxe5588
    Gridaxe5588 Light Load Member
    Nov 23, 2022
    126
    Thanks Received:
    168
    If that fuse is blown the APU wouldn't even start, that's where it gets it's power from it doesn't have its own battery.
  7. BigRed40
    Sep 24, 2024
    6
    Thanks Received:
    5
    Capacitor is shot. Fuse is fine
    ducnut and Gridaxe5588 Thank this.
  8. Gridaxe5588
    Nov 23, 2022
    126
    Thanks Received:
    168
    Now that you said that I remember one on a truck i drove doing that, haven't had a APU in year's only run a generator now and will never go back.
  9. ducnut
    ducnut Road Train Member
    Dec 31, 2010
    2,683
    Thanks Received:
    8,131
    SPI
    On a side note, you need to pull every single fuse in the box(es), when searching. I lost every light at the back, except the right turn signal. All my light-related fuses were good. Our tech found a slot marked with three letters I can’t remember, but, that fuse was blown. What the letters meant and why every rear light wasn’t on it, we’ve no idea. He said they’ve gotten in the habit of pulling every fuse, when searching for answers.
    Glad you found your answer. I hope this underwhelming ThermoKing APU never gives me issues, even though I know it will.
  10. BigRed40
    Sep 24, 2024
    6
    Thanks Received:
    5
    Yea it's totally separate from the truck lights. Apu has fuses in the Apu box and under the bunk. A 4 day headache. Tested the CCU board and boom 4.6 volts. That's how I know capacitor is bad
    ducnut Thanks this.
