Carroll Fulmer
Discussion in 'Freight Broker Forum' started by Johnathan Kimball, Jul 1, 2015.
  1. Johnathan Kimball
    Johnathan Kimball Bobtail Member
    Jul 1, 2015
    Thanks Received:
    I recently booked a load through Carroll Fulmer and late in the afternoon they pulled the load from me because they already had a truck at the pick-up location. Mind you, I had a SIGNED rate confirmation with this company and was told I had until 8pm to pick-up the load. This was going to be my first load with this company and they burned me real bad. I definitely do not recommend anyone to haul a load for this company because if they can pull a load from me they can pull a load from you.
  2. jbatmick
    jbatmick Road Train Member
    Dec 1, 2009
    2,197
    Thanks Received:
    2,501
    hastings, Fl
    Did you ask for TONU money ?
    d o g and flyingmusician Thank this.
  3. Johnathan Kimball
    Jul 1, 2015
    Thanks Received:
    I told them I was going to send them an invoice for the amount of the rate confirmation. What is TONU money?
  4. flyingmusician
    flyingmusician Road Train Member
    Feb 25, 2011
    4,288
    Thanks Received:
    10,905
    Jamestown, NC
    Truck Ordered Not Used.
    Should have been figured into your contract before you accepted the load to cover your ###.
    I'm a company driver even I know that lol
    HeWhoMustNotBeNamed and d o g Thank this.
  5. Sustanon
    Sustanon Light Load Member
    Dec 19, 2010
    220
    Thanks Received:
    155
    KY
    truck ordered not used
    d o g Thanks this.
  6. Oldman49
    Oldman49 Medium Load Member
    Jul 20, 2014
    353
    Thanks Received:
    300
    The learning curve just got a bit steeper.
    flyingmusician Thanks this.
  7. ira1377
    ira1377 Light Load Member
    May 10, 2011
    154
    Thanks Received:
    486
    Bradenton, Fl
    That's how you learn, he won't get burned again
  8. CasanovaCruiser
    CasanovaCruiser Road Train Member
    Jun 2, 2015
    1,712
    Thanks Received:
    2,669
    Indiana
    I've heard terrible things about this company. My girlfriend's parents live just down the road from a terminal and when they heard I was getting into the industry the first thing they said was, "don't you dare go to work for Carrol Fulmer"
  9. RedForeman
    RedForeman Momentum Conservationist
    Jan 30, 2011
    4,875
    Thanks Received:
    22,139
    We've run only two loads for them back in 2012, but I don't recall anything negative. Just ask the broker for a revised rate con with a TONU on it. If it was an honest mistake, they won't hesitate to pay you. The amount will be negotiable, unless you agreed to an amount in your carrier agreement or rate con (probably not).
    However, I'm not seeing the whole story. You say they pulled the load due to having another truck already there. So, how long was it from the time you booked to the time they cancelled? And did you already move toward or arrive at the shipper? This is important, because a TONU is intended to cover the lost opportunity to you for taking your truck off the market for some period of time, and possibly cost to move it. If they canceled the truck order fairly quick, you haven't been harmed. On the other hand, if they waited the entire day and canceled you late enough that you had little chance to re-book the truck, you should be paid. Likewise if you moved to the shipper and found out your load went out on another truck with no notice from the broker.
  10. BrokeringBad
    BrokeringBad Light Load Member
    Feb 12, 2015
    56
    Thanks Received:
    10
    Red has some valid points. You should at least look into the TONU.
