CB Not Working: Antenna Issues(???)
Discussion in 'CB Radio Forum' started by RadarRider, Nov 21, 2010.
  1. RadarRider
    RadarRider Bobtail Member
    Nov 21, 2010
    7
    Thanks Received:
    Smithfield, RI
    I decided to hook up a CB to my personal 4 wheel vehicle. I bought a brand-new Cobra 29 Chrome off of a friend & I had gotten the antenna components from a Pilot Travel Center. I didn't think I'd need a whip as big as the ones on my rig, so I just bought a 2 1/2' fiberglass whip & a 12' co-ax. The antenna is one of those clamp style ones & I have it mounted on the bumper of my Super Duty. The co-ax is nice & tight on the antenna & the CB ends.
    Now, the CB turns on/off fine, but I'm not getting any noise & the ANT light isn't on. I've checked both ends of the antenna wire & made sure the antenna was mounted firmly on the base & I'm still not getting anything. Did I mount the ant in a bad spot or is the ant &/or the co-ax a piece of crap? If it makes any difference, the company that man'd the antenna & co-ax is Truck Spec. Thanks in advance.
  2. Big_m
    Big_m Heavy Load Member
    Oct 13, 2009
    881
    Thanks Received:
    265
    Central Maryland
    This may sound dumb. But what is the setting of each switch & knob? And a 2 1/2 ft antenna is by no means the best. In fact it's one of the worst antennas for CB.
  3. geartow
    geartow Bobtail Member
    Jun 29, 2009
    35
    Thanks Received:
    7
    syracxuse ny
    2.5 ft antenna bumper mounted aint gonna hear diddly
  4. joplinlocal
    joplinlocal Light Load Member
    Sep 25, 2010
    212
    Thanks Received:
    112
    Joplin, MO
    Especially check the Ch 9 / 19 switch. This switch causes dead receive when dirty or misaligned. Would probably be a good idea to spray all switches and tuner down with contact cleaner.
    Are you sure the radio is brand new? Did you see the radio working before you bought it?
    Antenna light should come on when SWR reads 3:1 or higher, but these lights can easily go out of whack. Have you calibrated and read SWR via the radio's meter? What value is it showing?
  5. RadarRider
    Nov 21, 2010
    7
    Thanks Received:
    Smithfield, RI
    Thanks a lot, guys. I stopped # Pilot again & scooped up a Truck Spec magnet mounted antenna & now I'm finally talking to people. Just gotta do some tuning. Now; on a Cobra 29, I don't have a squelch knob. Which one of these knobs controls the squelch?
  6. jessejamesdallas
    Oct 3, 2008
    1,416
    Thanks Received:
    855
    Republic of Texas
    Just about all CB's have a squelch knob...Even the "Cheap ones"
    Yours will be the outer ring on the volume knob....Turn it clock-wise to squelch out what your hearing...Comes in handy when talking to someone who is very close to you...Thats about it...
  7. geartow
    Jun 29, 2009
    35
    Thanks Received:
    7
    syracxuse ny
    what is the diameter of the mag net you got ?
  8. squirrellsgnwild
    squirrellsgnwild Medium Load Member
    Jul 19, 2007
    469
    Thanks Received:
    51
    In that nuthouse they call California
