CDL questions
Discussion in 'Tanker, Bulk and Dump Trucking Forum' started by Ddr1992 579, Feb 23, 2020.
  1. Ddr1992 579
    Ddr1992 579 Medium Load Member
    Sep 10, 2018
    395
    Thanks Received:
    100
    Is a 2000 Ford f450 with a 16ft dump body with a 17,500 gvw towing a 28ft tag along trailer with a skid steer weighing about 19,000 and the same gvw be considered a cdl vehicle? Its about 35-40ft long and hydraulic brakes on the truck and trailer... I'm in Florida btw
  2. npok
    npok Light Load Member
    Sep 26, 2015
    160
    Thanks Received:
    172
    Yes, that's a class A combination. 17,500 + 19000 = 36500, which is way more than 26,001 lbs. That's the minimum weight for a class A combination.
  3. Ddr1992 579
    Sep 10, 2018
    395
    Thanks Received:
    100
    So it's not a class b? An f550 is smaller than a f650... ####...
  4. cncking2000
    cncking2000 Light Load Member
    Dec 5, 2018
    135
    Thanks Received:
    217
    If the trailer's GVWR exceeds 10,000 it is not Class B
    npok and FozzyNOK Thank this.
  5. x1Heavy
    x1Heavy Road Train Member
    Mar 5, 2016
    34,017
    Thanks Received:
    42,137
    White County, Arkansas
    Its straight up Class A
    Combination vehicle.
    Trailer GVWR is excess above 10,000 pounds. (NOT gross vehicle COMBINATION weight, just the total trailer weight, your 19000 pound bobcat does not help)
    Class B is already "Included" in those who hold a CDLA.
    HOWEVER, your vehicle brakes being liquid driven you WILL have a NO AIRBRAKES restriction on your CDL A if YOU TESTED with NON air brake vehicle. It will NOT be legal for you to touch a vehicle with airbrakes period.
