Changing roof from condo to mid.
Discussion in 'Freightliner Forum' started by Image, Jul 24, 2018.
  1. Image
    Image Light Load Member
    Mar 15, 2012
    69
    Thanks Received:
    17
    ND
    Does anyone know if I can take the tall condo roof off my 2003 century 120 and replace it with a mid height roof? Is it a pretty straight forward swap?
    Thanks
  2. Oldironfan
    Oldironfan Road Train Member
    May 22, 2017
    5,777
    Thanks Received:
    5,543
    It's possible. But not sure it would be easy or not. It's all epoxy sealed I think on top.
  3. kemosabi49
    Jan 13, 2013
    10,680
    Thanks Received:
    45,840
    SW Arkansas
    I saw a picture of a guy that did that. He used a 12'6" overpass.
  4. x1Heavy
    x1Heavy Road Train Member
    Mar 5, 2016
    34,017
    Thanks Received:
    42,137
    White County, Arkansas
    WHY?
    Sell the thing and buy a midroof built just like the way you want it.
    It is my theory that if you don't want a condo, leave it alone. Someone will want it. The reason being is that when you start sawing and gluing up there will liable to be leaks forever and ever. It's not worth it. Sell it and use the money to get a midroof you want.
  5. Oldironfan
    May 22, 2017
    5,777
    Thanks Received:
    5,543
    That makes it a real quick job to take it off. Just need the right amount of speed.
  6. special-k
    special-k Road Train Member
    Dec 27, 2008
    1,523
    Thanks Received:
    3,258
    Southern Ontario Canada
    If its a good truck and he like fld's what are the odds of finding a good used 2003 fld? Especially if his truck is spec'd well for his work. Pita for sure but not impossible at all.
    Cottonmouth85 and Image Thank this.
  7. AModelCat
    29,225
    Thanks Received:
    159,412
    It's definitely not a weekend and a case of beer kind of project. Do those trucks have the cab and sleeper integrated as one?
    Oldironfan Thanks this.
  8. Image
    Mar 15, 2012
    69
    Thanks Received:
    17
    ND
    Had this trick 7 years now and know it well. Have it setup like I want with some extra hp, 3rd fuel tank, eld exempt Detroit, etc...
    Would rather swap a roof than start over with a different used truck with potential unknown issues.
    The condo roof isn’t hurting anything, I’m just trying to build it into the look I want.
    Cottonmouth85 and Dave_in_AZ Thank this.
  9. Image
    Mar 15, 2012
    69
    Thanks Received:
    17
    ND
    Yes it’s integrated cab and sleeper. However there is a seem just above the door that runs around the whole cab. Looks like it should come apart.
    I just wanted to be sure the mid roof is a direct fit. I’m not worried about the difficulty of the job. As long as the mid roof will fit, that’s all I really needed to know.
  10. Oldironfan
    May 22, 2017
    5,777
    Thanks Received:
    5,543
    There are two general size Columbia cabs, short sleeper and xt I think.
