Check out my trailer, lol. Never even seen one like it before.
Discussion in 'Tanker, Bulk and Dump Trucking Forum' started by ethos, Mar 18, 2016.
  1. ethos
    ethos Road Train Member
    Mar 3, 2013
    4,249
    Thanks Received:
    9,905
    Houston
    [​IMG][/URL][/IMG] [​IMG]
  2. ethos
    Mar 3, 2013
    4,249
    Thanks Received:
    9,905
    Houston
  3. EZ Money
    EZ Money Road Train Member
    Oct 27, 2010
    3,251
    Thanks Received:
    2,478
    The East Side Gang,Charlotte,NC.
    She has a skirt on!.....First tanker I have seen with them.
    x1Heavy and Dominick253 Thank this.
  4. dca
    dca Road Train Member
    May 31, 2011
    6,834
    Thanks Received:
    11,427
    Earth
    cool and legal for California
    Dominick253 Thanks this.
  5. ethos
    Mar 3, 2013
    4,249
    Thanks Received:
    9,905
    Houston
    I know, it was preloaded at DOW in Hayward, CA. When I found it I was like WTH is all this crap. It also has more lights on it than a Christmas tree. It has these two red lights hanging off the bumper really low to the ground. They seem kinda gimmicky at first but I tell you backing into the hole this morning was the easiest back ever. Those lights really give you an easy reference and help you judge how far you are from the line. I like them.
  6. Lucidd
    Lucidd Light Load Member
    Mar 11, 2016
    113
    Thanks Received:
    26
    Very nice
  7. Thermos Bottle
    Thermos Bottle Light Load Member
    Apr 6, 2015
    281
    Thanks Received:
    16,713
    GA
    Haven't seen those side skirts before. I did see some very new looking tanks with super singles on them. Seems like you have a pretty nice and safe walkway above the ladder. Your sleeper looks about a foot bigger than ours. Am jealous.
  8. daf105paccar
    Apr 15, 2012
    6,564
    Thanks Received:
    7,293
    Ethos,those bumper lights have been common in the EU for the last 40y.
  9. ethos
    Mar 3, 2013
    4,249
    Thanks Received:
    9,905
    Houston
    Well I found an issue. Took off from Lake Havasu Loves and the first bump I hit absolutely destroyed the inside of my truck, stuff went everywhere including things that have never fallen. I knew immediately something was wrong, bad wrong and I figured something had gone wrong with the suspension.
    But since the skirts go all the way around there is no access to under the trailer. Finally, I found an angle where I could inspect the airbags and sure enough they don't have air. Hmmmm, now what could have changed to cause this because it wasn't a problem last night? Well I don't know but I saw a valve under the trailer axles but again no way to get in. Finally, and you can see this from the pic, I climbed the ladder and kinda jumped in between the skirt and trailer and then duck walked all the way back and flipped that valve. Air bags start to inflate problem solved. I zip tied the valve. Problem solved.
    Now they designed this in a way where you can see all of your lines and stuff from outside the skirt, you can even see the very bottoms of your airbags but can't tell if they are inflated. Basically I am going to have to call Safety because this isn't going to work.
    A. PTI is not as thorough.
    B. I assume nobody wants me jumping into that little space and duck walking back.
    C. Access in needed. How am I going to break loose frozen brakes, zip tie brake lines that come loose etc? All things that us truckers fix regularly.
    D. Any maintenance in general, particularly road side, is going to be dangerous and difficult.
    White_Knuckle_Newbie and albert l Thank this.
  10. daf105paccar
    Apr 15, 2012
    6,564
    Thanks Received:
    7,293
    Speaking off safety...........why is there a bungee on the side off your truck?:p:eek:
