Checking Lug Nut Torque
Discussion in 'Questions From New Drivers' started by lantern756, Nov 20, 2017.
  1. lantern756
    lantern756 Bobtail Member
    Nov 9, 2017
    23
    Thanks Received:
    On a pre-trip inspection, how is everyone checking to make sure the lug nuts are properly tight? Besides using a torque wrench any good suggestions? Also, does anyone use those plastic wheel checks?
  2. x1Heavy
    x1Heavy Road Train Member
    Mar 5, 2016
    34,017
    Thanks Received:
    42,135
    White County, Arkansas
    If they spin by hand, shop needs to fix it.
    And yes they do shake loose on bad roads. Usually with the steel wheels.
    BB203 and Lepton1 Thank this.
  3. 6wheeler
    6wheeler Road Train Member
    Aug 30, 2009
    2,696
    Thanks Received:
    4,774
    If you see rust, its loose.
    BB203, x1Heavy and TripleSix Thank this.
  4. AModelCat
    29,154
    Thanks Received:
    158,528
    If they're loose, you'll usually see a shiny rub mark around the flange of the nut on the rim. Rust streaks running outwards from the nut are another indicator. Easier to see in the rain.
    I do have the green flags on all mine. Makes it easy to see if the nuts are moving.
  5. rolls canardly
    rolls canardly Road Train Member
    Feb 7, 2009
    1,608
    Thanks Received:
    3,780
    mt. pocono. pa.
    I got a set of those fluorescent wheel check arrows
    from a wrecked LP Gas truck in the junkyard.
    No more concern.
    Jazz1 Thanks this.
  6. Mark Kling
    Mark Kling Technology Contributor
    Sep 23, 2007
    10,935
    Thanks Received:
    4,216
    Statesville, NC
  7. WesternPlains
    Sep 1, 2017
    6,298
    Thanks Received:
    53,192
    I picked up one from an experienced trucker: If they are wet. They are probably loose.
    Of course this is when they shouldn't be. After everything else has dried.
    x1Heavy Thanks this.
  8. Pumpkin Oval Head
    Pumpkin Oval Head Road Train Member
    Jun 24, 2010
    1,679
    Thanks Received:
    1,155
    Scranton PA
    What cdl school did you go to?
  9. Txdriver77
    Txdriver77 Medium Load Member
    Sep 7, 2016
    365
    Thanks Received:
    26,641
    Texas
    if it's loose, ill hand tighten it and then put a couple tack welds to hold it.
    just kidding folks!
    buddyd157 Thanks this.
  10. TravR1
    TravR1 Road Train Member
    Nov 9, 2017
    3,693
    Thanks Received:
    9,579
    TX
    Not driving yet, but I am willing to bet wheel checks for most trucks consists of only giving the wheel a kick, or just a quick glance, or nothing at all.
    Also post trip inspections are probably never done.
    Human nature.
