Class A licesce
Discussion in 'Expediter and Hot Shot Trucking Forum' started by Seguy, Jul 19, 2011.
  1. Seguy
    Seguy Bobtail Member
    May 17, 2010
    20
    Thanks Received:
    Daphne, Al
    Does a class A license cover Hotshot loads, 1 ton- 2 1/2 ton trucks.
  2. Bigarmin88
    Bigarmin88 Road Train Member
    Aug 30, 2008
    1,791
    Thanks Received:
    376
    Tampa Bay Fl
    Class A covers any motor vehicle over 26,001bls.Yeah you should be good.
  3. WMGUY
    WMGUY Road Train Member
    Jan 1, 2011
    1,684
    Thanks Received:
    800
    Nine Mile Falls, WA
    what he said.
    there are some hot shots that run under the 26,000 lbs mark and don't need one
    but is you have a class A you are good to go
  4. Bigarmin88
    Aug 30, 2008
    1,791
    Thanks Received:
    376
    Tampa Bay Fl
    That's the sweet thing about class A CDL,you can drive anything,lol.
    SHO-TYME Thanks this.
  5. Seguy
    May 17, 2010
    20
    Thanks Received:
    Daphne, Al
    Do you have to run a log book running hotshot
  6. VIDEODROME
    VIDEODROME Road Train Member
    Jun 7, 2007
    1,487
    Thanks Received:
    1,297
    angola, in
    I think a few don't but most do. It probably depends on the size and weight of the vehicle.
  7. Bigarmin88
    Aug 30, 2008
    1,791
    Thanks Received:
    376
    Tampa Bay Fl
    Yes you do if your over 10,000bls I think.
  8. SMBdriver
    SMBdriver Light Load Member
    Nov 28, 2010
    163
    Thanks Received:
    85
    This is a myth I hear over and over again, that hot shot drivers are exempt from logging hours of service. It simply is not true.
    If you are a motor carrier, or drive a CMV for a motor carrier, you must keep records of your hours of service. There is no exception in FMCSA rules for hot shots.
    However, there is a definition of what constitutes a Commercial Vehicle... And it states that if any one of these apply, it is a CMV...
    • Weighs 10,001 pounds or more
    • Has a gross vehicle weight rating or gross combination weight rating of 10,001 pounds or more
    • Is designed or used to transport 16 or more passengers (including the driver) not for compensation
    • Is designed or used to transport 9 or more passengers (including the driver) for compensation
    • A vehicle that is involved in Interstate or intrastate commerce and is transporting hazardous materials in a quantity requiring placards is also considered a CMV.
    Using this definition, a typical Dodge Ram 2500 falls under the 10,001 with the GVWR, but well over 10,001 with it's GCWR of about 15,000. Since most hot shot rigs are 3500s or better, which have GVWR of over 10,001, logging would be required. Any size vehicle carrying hazmat requiring placarding automatically requires logging.
    As a hot shot O/O (and Motor Carrier) I log just like an O/O of a big truck does and am required to follow all of the same rules.
    From what I see on the road, I think there are a lot of hot shots out there who aren't running legal in any way. I see a lot of unmarked pickup trucks, not running apportioned tags, no IFTA stickers, and it's probably a logical conclusion that they don't have operating authority (or run illegal for some trucking companies who do but don't want the expense of actually hiring class A CDL drivers for their hot shot loads), that probably aren't correctly insured for commercial transport, and probably aren't keeping logs...but I wouldn't want to be one of them when they get pulled over...
    Here's the link to FMCSA
    http://www.fmcsa.dot.gov/rules-regulations/administration/fmcsr/fmcsrruletext.aspx?reg=395.8&keyword=log%20book
  9. THBatMan8
    THBatMan8 Road Train Member
    Feb 13, 2011
    1,478
    Thanks Received:
    469
    Wherever I park
    Just because you're driving a CMV doesn't conclude you need to have logs.
    Also, GVW =/= curb weight.
  10. SHO-TYME
    SHO-TYME Road Train Member
    Apr 20, 2011
    3,425
    Thanks Received:
    3,179
    Dahlonega, GA
    It's better to have a log book and not need it than the other way around, cheaper too.
    Same goes for Med cards.
