Class B CDL
Discussion in 'Questions From New Drivers' started by TruckDriverJohn, Jun 22, 2011.
  1. TruckDriverJohn
    TruckDriverJohn Bobtail Member
    Jun 20, 2011
    9
    Thanks Received:
    Tyler Texas
    I have a class B CDL and I start with Stevens next month. My question is: Since I have a class B I know I have to take a few more tests, but I was wondering what I needed to do to get a learners permit for a Class A? Would a B suffice with an instructor present?
    I hope that makes sense. :biggrin_25512:
    John
  2. Rerun8963
    Rerun8963 Road Train Member
    Mar 30, 2006
    3,917
    Thanks Received:
    2,012
    ova-hereee
    to have a Class A CDL, you MUST have air brakes, combination vehicles and general knowledge.
    so, if you have a class B as you say, then you already have, general knowledge, and air brakes, so all you would need is the combination vehicles
    no, a class B will NOT suffice, as you'd be in violation of driving without proper documents.
  3. Tez
    Tez Light Load Member
    Jun 23, 2011
    64
    Thanks Received:
    5
    Bradford, PA
    Yeah, you'd have to have your class A permit before you can even start to operate a class A truck. The last poster is correct in that is the only written test you will have to take. The road test is a much different story, not quite as simple. Depending on which state you live in you will have to learn 3-5 different backing maneuvers and other various requirements. Good luck.
  4. WitchingHour
    WitchingHour Road Train Member
    Apr 1, 2011
    3,424
    Thanks Received:
    2,143
    Broomfield, CO
    It actually is possible to have a Class A without air brakes, but that's a bit irrelevant here - you're going to need it, if you don't already.
    To get the permit, you just need to take air brakes (if you haven't already) and combination vehicles, as stated above. Not really a whole lot to it. If you wanted to, you could also test for endorsements, such as tanker, double trailers (basically a rehash of combination vehicles).... and you could do the written for hazmat, but there's a bit more involved in getting that.
  5. THBatMan8
    THBatMan8 Road Train Member
    Feb 13, 2011
    1,478
    Thanks Received:
    469
    Wherever I park
    No, because you're talking about two different classes of vehicles. You need a permit before you can drive a combination vehicle. You can't drive a larger vehicle than what your license class allows.
