Classic issue plz help
Discussion in 'Ask An Owner Operator' started by Classic29, Apr 29, 2022.
  1. Classic29
    Classic29 Bobtail Member
    Apr 28, 2022
    8
    Thanks Received:
    Hey can someone please help me with voltage gauge and fuel gauge on my classic.
    1. Fuel gauge works fine if my fan is off but as soon as i turn my fan on fuel gauge starts falling off.
    2. Voltage gauge- it keeps on showing fluctuations between 12.5 to 13.9 or maybe hits 14 or above once in a while.
    I’m assuming maybe a short circuit or something somewhere. I just needs someone to point me in right direction or where to start from. (Detroit 2008 fully deleted) alternator wiring cleaned all the way. And motor has new sensor Harness and injector harness.
  2. Diesel Dave
    Jan 20, 2010
    8,740
    Thanks Received:
    25,154
    Hesperia, Ca.
    Seen this same post somewhere else last night.
  3. Ridgeline
    22,418
    Thanks Received:
    116,654
    Check your grounds
  4. Jed2009
    Jed2009 Light Load Member
    Jan 8, 2020
    195
    Thanks Received:
    573
    Midwest
    I think it’s the third thread on the same topic, different forums. OP have you considered just taking it in to the experts and pay to have it fixed? Shidd happens.
  5. pavrom
    pavrom Road Train Member
    Apr 29, 2012
    3,185
    Thanks Received:
    7,305
    NE illinois
    2. ...clean all you thick cables ...i had same thing after one month of new alternator , checked all my batteries ( one had to be replaced ) , cleaned all battery cables and felt like wow ...replaced battery connectors with volvo type as well
    Rideandrepair Thanks this.
  6. Classic29
    Apr 28, 2022
    8
    Thanks Received:
    I already replaced battery connection with Volvo type Connectors and it shows 14.2 on batteries. But my problem is more likely just with dash gauges. Each gauge has 6 wire harness connecting all gauges in dash and ending up at speedometer. But I couldn’t seem to figure out ground cable out of these 6.
  7. Ridgeline
    22,418
    Thanks Received:
    116,654
    Most likely they are multiplexed gauges.
