Codes
Discussion in 'Ask An Owner Operator' started by Josecarlos, Sep 11, 2019.
  1. Josecarlos
    Josecarlos Bobtail Member
    Sep 11, 2019
    8
    Thanks Received:
    Hi guys I have a paccar mx and I have a code P1652. Anybody can help me with that code
  2. Josecarlos
    Sep 11, 2019
    8
    Thanks Received:
    Hello everyone. I need help. I have a paccar mx13, and I also have a code p1652. Somone can help me to understand this code. Thanks
  3. marmonman
    marmonman Road Train Member
    Dec 14, 2009
    1,417
    Thanks Received:
    2,842
    central illinois
    According to Google it's high voltage to the ECM
    Diesel Dave and Josecarlos Thank this.
  4. Diesel Dave
    Jan 20, 2010
    8,722
    Thanks Received:
    24,979
    Hesperia, Ca.
    Google can be your friend. I found that code. But can’t download it.
    Josecarlos Thanks this.
  5. Diesel Dave
    Jan 20, 2010
    8,722
    Thanks Received:
    24,979
    Hesperia, Ca.
    It says it’s either over charging and or a short circuit and it can Fry your ECM. It could be a faulty harness etc. It warns not to drive it until it’s checked out.
  6. Josecarlos
    Sep 11, 2019
    8
    Thanks Received:
    I'm working on it, when I put the ignition on the ECM sey the voltage is 12.7 but when started it going low 2.5 and don't accelerated more than 13 rpm I don't know what's the problem
  7. Josecarlos
    Sep 11, 2019
    8
    Thanks Received:
  8. Diesel Dave
    Jan 20, 2010
    8,722
    Thanks Received:
    24,979
    Hesperia, Ca.
    Did you check the battery connectors ?
  9. Josecarlos
    Sep 11, 2019
    8
    Thanks Received:
    Yes and check the batterys too
  10. Josecarlos
    Sep 11, 2019
    8
    Thanks Received:
    Also sey the voltage control sensor is bad but I don't know where is located in my truck
