Comment on my antenna please.
Discussion in 'CB Radio Forum' started by Snailexpress, Aug 13, 2023.
  1. Snailexpress
    Apr 28, 2014
    2,675
    Thanks Received:
    6,069
    Rocky
    New cable to OEM Volvo antenna. Why impedance is 100 Ohm? Screenshot (50).png
  2. Ridgeline
    22,768
    Thanks Received:
    124,352
    cable length 50.3 meters??
    terminate the end of the coax with a 50 ohm load and see what happens.
    Snailexpress Thanks this.
  3. Ridgeline
    22,768
    Thanks Received:
    124,352
    no comments from the experts?
    Wow ... just wow.
  4. Xcis
    Xcis Medium Load Member
    Jul 9, 2008
    497
    Thanks Received:
    269
    Bridgeport, Pa
    Sorry, I am not an expert but here is my opinion. This sounds like the multiplex system from hell. Multiplexing different signals on one system - proof technology is not always the best solution. This is why more people are bypassing what the truck came with and installing their own 50 ohm coax between the antenna on the driver's door and the CB radio. The KISS method: simple, cheap and very effective fix.
    Snailexpress and mike5511 Thank this.
  5. Snailexpress
    Apr 28, 2014
    2,675
    Thanks Received:
    6,069
    Rocky
    OEM system bypassed with 18 feet cable from truck stop. Antenna installed on the rear of the Volvo sleeper. Cable itself with 50 ohm load attached is OK SWR 1.01. Antenna itself is OK with SWR 1.08. But connected together system is not what i expect.
  6. Night Stalker10
    Night Stalker10 Road Train Member
    Jun 26, 2017
    1,699
    Thanks Received:
    1,271
    Is your Nano vna still showing an impedance of 100 ohms? What's the reading for 27.205?
    Edit: What radio and antenna are you using? Are you only talking and receiving a mile or two?
  7. Snailexpress
    Apr 28, 2014
    2,675
    Thanks Received:
    6,069
    Rocky
    Yes, receiving is bad. Radio Anytone working good in my bud truck. Cable with dummy load at the antenna end tested OK. Antenna tested OK with VNA connected directly to antenna.
  8. Night Stalker10
    Jun 26, 2017
    1,699
    Thanks Received:
    1,271
    What's the RL (return loss) of your antenna system according to the Nano on channel 20?
  9. Snailexpress
    Apr 28, 2014
    2,675
    Thanks Received:
    6,069
    Rocky
    -2.28 dB
  10. Night Stalker10
    Jun 26, 2017
    1,699
    Thanks Received:
    1,271
    Okay, that's not good. Your problem is due to a lack of RF ground. It's a common problem with today's trucks. Even though guys driving Volvo trucks claim the trucks have metal in the cabs, they still seem to have the same problem as other trucks have with their CB antenna system.
    You need to add ground straps to the cab. It's known as bonding. Here's a great website that explains it.
    Bonding
    If this doesn't solve the problem, then I'm not sure what would.
    mike5511 and Snailexpress Thank this.
