Coned pins for flip axle
Discussion in 'Heavy Haul Trucking Forum' started by blacklabel, Nov 13, 2016.
  1. blacklabel
    blacklabel Heavy Load Member
    Nov 6, 2011
    870
    Thanks Received:
    1,268
    MO
    Where can I get these at, or do they need to be made? I have blunt ended pins and would like a coned end. All input appreciated.
  2. passingthru69
    Jul 12, 2009
    8,740
    Thanks Received:
    34,849
    davenport,Ia / ratchaburi, thailand
    You got a grinder. You can grind them down yourself
    blacklabel and johndeere4020 Thank this.
  3. Superhauler
    Superhauler TEACHER OF MEN
    Jan 30, 2010
    12,209
    Thanks Received:
    100,730
    keep stroking.
    Know anyone with a plasma cutter? I don't know what type trailer you have but trailking pins are tapered on one end. The best pins I have found are the hitch pins from D8,s any cat shop has them.
    MJ1657, johndeere4020, Oxbow and 2 others Thank this.
  4. Rontonio
    Rontonio Road Train Member
    Aug 9, 2009
    6,292
    Thanks Received:
    45,819
    You can order a set from the trailer mfg, they are not that expensive, trust me I know, unless of course you need them overnighted....
    johndeere4020, Oxbow and blacklabel Thank this.
  5. passingthru69
    Jul 12, 2009
    8,740
    Thanks Received:
    34,849
    I carry at least one spare
    johndeere4020 and blacklabel Thank this.
  6. blacklabel
    Nov 6, 2011
    870
    Thanks Received:
    1,268
    MO
    Thanks guys I'll look at the Cat pins and mfg for a set. I just have some that the dealer had laying around when I picked this unit up and they cost me an hr or more of my life trying to get last one in. I could've had a tapered one in just a few min
    johndeere4020 Thanks this.
  7. Superhauler
    Jan 30, 2010
    12,209
    Thanks Received:
    100,730
    keep stroking.
    If you have mech. Neck dump air suspension. Then if it has it raise the trailer suspension, with trailer brakes released and air bags on flip deflated you can fanagle the axle around some to slip the pins in. Then I lay the shims in last if your setup uses them
  8. passingthru69
    Jul 12, 2009
    8,740
    Thanks Received:
    34,849
    Raise and lower is your friend on pin install and removal
    MJ1657, johndeere4020 and blacklabel Thank this.
  9. blacklabel
    Nov 6, 2011
    870
    Thanks Received:
    1,268
    MO
    Yeah it was 2/3mm off and a coned end would've been in alot sooner. Thanks again for your help guys
    MJ1657 Thanks this.
  10. johndeere4020
    Jan 1, 2010
    8,522
    Thanks Received:
    119,292
    This is the truth, on my pin on I have two quarter turn valves that I can open and close to raise and lower the axle suspension. I can usually put my pins in by hand, I can take a picture if it helps.
