Converting triaxle to spread axle
Discussion in 'Ask An Owner Operator' started by Marmon110P, Nov 9, 2020.
  1. Marmon110P
    Marmon110P Light Load Member
    Feb 24, 2019
    177
    Thanks Received:
    183
    I've got a line on alot of cheap tri axle 53' flatbeds and I'm wondering is there is a standard axle spread spacing on those where removing the center axle would make it a legal tandem spread?
  2. snowwy
    snowwy Road Train Member
    Jul 6, 2009
    20,558
    Thanks Received:
    13,286
    The standard setup is 10 ft 4 in.
    Some trailers are 8.2
  3. cke
    cke Road Train Member
    Aug 4, 2013
    5,973
    Thanks Received:
    73,502
    Colfax Wi
    Standard spread is 10ft 1 inch
    D.Tibbitt Thanks this.
  4. lester
    Jan 2, 2012
    2,920
    Thanks Received:
    7,890
    NW, Iowa
    Find the weight and measures chart for your state or states you run. I think 10ft 2in gets you 40k and as your spread goes down in length so does the weight
  5. snowwy
    Jul 6, 2009
    20,558
    Thanks Received:
    13,286
    You're right. 2 inches.
    D.Tibbitt and cke Thank this.
  6. snowwy
    Jul 6, 2009
    20,558
    Thanks Received:
    13,286
    8.4 is 38
    9.3 is 39
    10.2 is 40.
    If you're 8.3 or less. 34.
    D.Tibbitt, cke and lester Thank this.
