Cruise and jakes not working.
Discussion in 'Peterbilt Forum' started by kwforage, Apr 1, 2017.
  1. kwforage
    kwforage Road Train Member
    Jun 3, 2007
    1,047
    Thanks Received:
    472
    Wisconsin
    95' 378 with a 3406E. Cruise and jakes do not work.. Clutch switch is fine. Any ideas?
  2. boneebone
    boneebone Road Train Member
    Mar 13, 2009
    2,296
    Thanks Received:
    2,367
    Check your Brake Switch.
    kwforage, Hammer166, SAR and 1 other person Thank this.
  3. Hammer166
    Aug 18, 2007
    7,460
    Thanks Received:
    27,046
    ~8600+' and loving it!
    This. You'll have two switches, the normally closed one is the one for cruise/Jake. The NO switch is for the brake lights
    BUMBACLADWAR, kwforage and Dave_in_AZ Thank this.
  4. kwforage
    Jun 3, 2007
    1,047
    Thanks Received:
    472
    Wisconsin
    The one for the cruise/jakes is located next to the stop light switch in the block infront of the pedals?
  5. Hammer166
    Aug 18, 2007
    7,460
    Thanks Received:
    27,046
    That's how most trucks of that era were setup. I've seen some where it was all one switch (it would have 3 terminals) but I can't remember what truck that was.
  6. mslashbar
    mslashbar Medium Load Member
    Jul 22, 2009
    601
    Thanks Received:
    808
    elizabeth,co
    Could also be something in the fuel pedal.
  7. Hammer166
    Aug 18, 2007
    7,460
    Thanks Received:
    27,046
    Throttle won't kill the cruise, though.
  8. mslashbar
    Jul 22, 2009
    601
    Thanks Received:
    808
    elizabeth,co
    Brake switch wouldn't kill the jakes though either. When you give it fuel I think it overrides the cruise, I could be wrong. It could be set up where the jakes won't work with the cruise on.
  9. Diesel Dave
    Jan 20, 2010
    8,754
    Thanks Received:
    25,244
    Hesperia, Ca.
    I remembered a former neighbor of mine had a similar issue. He was told it was the Throttle Position Sensor. Well he replaced it and it solved the problem.
  10. Hammer166
    Aug 18, 2007
    7,460
    Thanks Received:
    27,046
    Yes, it will override it once you'll put more pedal than the cruise setting is calling for.
    A lot of those E-models came programmed where the jakes wouldn't come on until you touched the brakes.
