cruise control/engine brake not working - volvo
Discussion in 'Experienced Truckers' Advice' started by soon2betrucking, Sep 19, 2008.
  1. soon2betrucking
    soon2betrucking Road Train Member
    Sep 28, 2007
    1,658
    Thanks Received:
    473
    Philadelphia, Pa
    i posted about my cruise control and my engine break not working a while back, however i am unable to find the thread. i drive a Volvo, weather this works on just volvo's or all the trucks i dont no.
    i found out today that thier is a sensor built into the clutch peddle, and apprently this happens all the time, that sensor goes bad, and it wont allow your engine break or your cruise control not to work, well, untill you can get into the shop to get it fixed, you can just put your foot under the clutch peddle and lift up, and both will work. now, your foot will get really tired after 10 mins of hold up onit if you are using your cruise control, so just get a bungee cord and put on there to hold it up, but dont forget you still need to be able to press down the peddle for normeal operation of the peddle.
    just thought that id share this with everyone els
  2. Donk
    Donk Have a Cup Of Concrete
    Apr 27, 2008
    1,643
    Thanks Received:
    9,232
    The sensor should be on a bracket with slotted bold holes. To fic your problem you should be able to adjust the height of the switch.
    it needs to activate at the first touch of the clutch or brake pedals. The brakes are usually an air operated sensor.
    86scotty Thanks this.
  3. mc8541ss
    mc8541ss Road Train Member
    Sep 22, 2007
    1,467
    Thanks Received:
    2,015
    Lower Alabama
    Also on my Volvo, its a 95, When you turn the key on I have to wait for all of the dummy lights in the dash to go out before starting........If not, same deal, no jakes no cruise......
  4. pete1983
    pete1983 Light Load Member
    Aug 18, 2008
    55
    Thanks Received:
    5
    alvin,tx
    my volvo is the same way lol
  5. User Name
    User Name Light Load Member
    Aug 20, 2008
    143
    Thanks Received:
    36
    Midwest
    I had a 2000 Volvo that would have the same symptoms, no jake, no cruise, and also it would idle a little fast. Mine needed a TPS (throttle position sensor) that's on the back side of the gas peddle. I replaced two of them in the time I had that truck.
  6. Eso
    Eso Bobtail Member
    Jul 24, 2014
    45
    Thanks Received:
    6
    Yes you should wait all lights got on and off before you start your engine.
    After you start...push and hold brake pedal for 3 sec to activate cruise control....it says in instructions on my sun visor.
    In case your brake pedal is hanging to low put some elastic rubber around brake pedal and hookup(hang) above pedal .
  7. Joschmotrucker
    Joschmotrucker Light Load Member
    Apr 17, 2012
    163
    Thanks Received:
    84
    TN
    Really common on the Volvos for the clutch pedal return spring to break. More than likely a new spring will fix this.
  8. marmon96
    marmon96 Light Load Member
    Dec 27, 2013
    98
    Thanks Received:
    57
    gardner,ma.
    i gotta know do volvos still come with a bozo the clown suit?
  9. Eso
    Eso Bobtail Member
    Jul 24, 2014
    45
    Thanks Received:
    6
    New spring will fix it....but it helps until you find shop
    Especially if you don't know whats problem :)
  10. antony2222
    antony2222 Bobtail Member
    Apr 2, 2015
    6
    Thanks Received:
    Hello everyone, I have a 99 Volvo VNL64T, and my cruise works while I drive on the highway, but when I park and need to set cruise for idle (otherwise the truck will shut off) it doesnt work, and the truck idles low. Anyone have an idea of how to fix this problem, or at least where to look?
