Cruise-Control High Idle Control Not Working...
Discussion in 'Peterbilt Forum' started by Working Class Patriot, Feb 9, 2014.
  1. Working Class Patriot
    Working Class Patriot Road Train Member
    Jan 17, 2008
    12,683
    Thanks Received:
    23,165
    Wherever and Whenever...
    My high idle took a dump on me today....I can bump up the idle to 800 rpms with the Cruise select and the Cruise-control in the off position...But with the Cruise on the cruise select does nothing....
    Anyone have any ideas?
  2. Flightline
    Flightline Road Train Member
    Oct 1, 2011
    2,345
    Thanks Received:
    1,165
    Almost There
    Just a thought, lift your clutch pedal. Sometimes they stick 1/2 inch down but that usually knocks the cruise completly out, not partial.
    Working Class Patriot Thanks this.
  3. TheTruckdr
    TheTruckdr Bobtail Member
    Dec 19, 2009
    22
    Thanks Received:
    6
    St Joe MO
    Press the clutch and/or brake pedal to reset the cruise. That might work.
  4. Working Class Patriot
    Jan 17, 2008
    12,683
    Thanks Received:
    23,165
    Just tried it....No go....
    Thanks though.....
    I'm just concerned about the oil pressure...Is 5 psi going to make a difference?
  5. TheTruckdr
    Dec 19, 2009
    22
    Thanks Received:
    6
    St Joe MO
    Yes. Engine protect is probably on. Check the oil.
  6. Working Class Patriot
    Jan 17, 2008
    12,683
    Thanks Received:
    23,165
    Ok....I went back and checked the clutch pedal....I'll be dayumed...
    It was down about an 1/8" or so....
    What the heck?......:smt017:dontknow:...That's never happened before......:biggrin_2559:
    Thanks again.....:biggrin_25525:
    TheTruckdr Thanks this.
  7. Working Class Patriot
    Jan 17, 2008
    12,683
    Thanks Received:
    23,165
    If I wasn't stuck here W/O Vail summit....I'd get out and buy you guys your favorite brews.....:biggrin_255:
  8. Cranky Yankee
    Cranky Yankee Cranky old ######
    Jan 31, 2012
    15,317
    Thanks Received:
    209
    Green Bay Wi
    everything in life has
    "never happened before"
    once :biggrin_25525:
  9. Working Class Patriot
    Jan 17, 2008
    12,683
    Thanks Received:
    23,165
    That's what "She" said.....:biggrin_25525::biggrin_2559:
