CSA Reports/ what to focus on when reviewing
Discussion in 'Questions From New Drivers' started by pinkpretty, Feb 19, 2014.
  1. pinkpretty
    pinkpretty Bobtail Member
    Feb 14, 2014
    22
    Thanks Received:
    23
    Michigan->headed for Ohio
    Husband and I have noted the importance of reviewing the CSA's of trucking companies as he narrows down his company preferences. So we head over to the online safety measurement site, and are comparing carriers.
    http://ai.fmcsa.dot.gov/SMS/Data/carrier.aspx?enc=m7kMnBcoEvj4mKzOC/UINA==
    It seems to me we should be looking at all the results as a whole, is that correct? For those of you that are used to looking at these reports, is there one area we should focus in on as we look at one carrier to the next?
    much thanks (again!)
  2. Sublime
    Sublime Road Train Member
    Jan 18, 2013
    1,529
    Thanks Received:
    1,896
    Twin Cities, MN
    If he's going to be a company driver I'd be looking at the maintenance part. That would indicate how well they maintain their equipment.
    pinkpretty Thanks this.
  3. Green-eyed Lady
    Green-eyed Lady Light Load Member
    Jan 15, 2014
    281
    Thanks Received:
    206
    Dallas TX
    I agree with Sublime...maintenance, first and foremost.
    Then you want to look at their HOS compliance. Click and look at where most of those violations are.
    If you see a lot of issues r/t over hours, and then look at the Safety category and see where the drivers are speeding, this may translate into a company that is NOT safety minded. They may be pushing their drivers and that is a company you want to avoid.
    Sublime and pinkpretty Thank this.
  4. pinkpretty
    Feb 14, 2014
    22
    Thanks Received:
    23
    Fabulous info! thank you for sharing!
    Green-eyed Lady Thanks this.
  5. double yellow
    Aug 28, 2011
    5,946
    Thanks Received:
    10,066
    State of Jefferson
    Maverick doesn't look too bad. That unsafe driving seems worse than it is -- most of the points came from speeding 6-10 over and most of those tickets came from IN. So they were probably going 62-65 in a 65-70zone where the truck speed limit is 55 but where you'll never see any truck driving 55...
  6. Chinatown
    Chinatown Road Train Member
    Aug 28, 2011
    74,806
    Thanks Received:
    170,474
    Henderson, NV & Orient
    NTB is a company worth researching.
  7. pinkpretty
    Feb 14, 2014
    22
    Thanks Received:
    23
    thanks double yellow, I'll remember that when looking at those violations. It makes sense to consider the "whole" picture rather than just a straight number
    Indeed they are, Chinatown.. off to peak around some more
  8. another driver35
    another driver35 Bobtail Member
    Feb 12, 2014
    16
    Thanks Received:
    9
    you want to look at the score in a whole since. maitenance can be an issue. 9 times out of 10. d.o.t stop trucks over a high hos score. that is where they make the most money. so if the h.o.s score is low. or you see in the trucking company website were the are using e-logs. then the trucking company has either taken action to end the hos tickets. or the fmcsa has stepped in an told them either go to e-logs. or go out of business. once the d.o.t / cop sees the electronic drivers logs in use sticker on the side of the truck. they tend to leave those trucks alone. the only time you see an e-log truck stopped is either the driver was doing something wrong. a light was burnt out. or the cop is play catch up on inspections. before the cops bosses yell at him.
    to give you some idea on what a good csa score looks like. here's a company I have been looking at...
    http://ai.fmcsa.dot.gov/SMS/Data/carrier.aspx?enc=uM7/Tjb0WAXfUgy73hCLUA==
