Cummins ISM CM876 hard start ONLY when hot
Discussion in 'Trucks [ Eighteen Wheelers ]' started by oldirtyjustin, Aug 2, 2016.
  1. oldirtyjustin
    oldirtyjustin Bobtail Member
    Apr 5, 2014
    13
    Thanks Received:
    I have a cummins ism in the shop and the complaint is a hard start when hot. i have only been able to duplicate the problem 4 times after running the engine for an hour, shutdown and it will crank for 10 to 15 seconds and fire up sometimes misfire a bit but usually run fine. the truck has brand new injectors and fuel pump. When issue is present and it won't start i have 150psi of fuel pressure out of the pump. Anyone ever come across this? I am going to try a test ECM tomorrow
  2. oldirtyjustin
    Apr 5, 2014
    13
    Thanks Received:
    i keep thinking must be a fuel issue must be a fuel issue but 150psi while cranking is plenty of pressure, when it won't start engine cranks at 350rpms. No faults. Seems to have some blow by which is something i need to measure, but again only happens when hot and not everytime
  3. oldirtyjustin
    Apr 5, 2014
    13
    Thanks Received:
    also engine has egr and vgt actuated turbo, both have been checked
  4. oldirtyjustin
    Apr 5, 2014
    13
    Thanks Received:
    nothing??
  5. pup
    pup Light Load Member
    Dec 3, 2011
    252
    Thanks Received:
    256
    n.h.
    do you have the insite program? are there any fault codes?
  6. Heavyd
    Heavyd Road Train Member
    Feb 4, 2009
    7,783
    Thanks Received:
    6,220
    I'm not sure if the shutdown solenoid is before or after the compuchek fitting, but this is something that will act up when hot versus cold. Might be worth a try.
    lovesthedrive Thanks this.
  7. oldirtyjustin
    Apr 5, 2014
    13
    Thanks Received:
    no faults and it has a brand new pump which has a new fuel shutoff solenoid on it, I have insite. just put a test ECM on it, keeping fingers crossed
  8. oldirtyjustin
    Apr 5, 2014
    13
    Thanks Received:
    theory is when ECM gets hot connections in the ECM expand
  9. oldirtyjustin
    Apr 5, 2014
    13
    Thanks Received:
    well that wasn't the problem haha, blow by is in spec as well
