Dash cam: CYA or take it up the rear
Discussion in 'Werner' started by HiLoSapien, Apr 22, 2019.
  1. HiLoSapien
    HiLoSapien Light Load Member
    Mar 1, 2017
    167
    Thanks Received:
    324
    I was hit by a driver who made an unsafe lane change and drove right into my front end, captured on my cam. I showed the video to the responding officer, and later to Werner safety at a terminal. Safety wanted to charge me with a preventable, require remedial driver training, and a pile of cbts. I told them, Don't bother, I don't work for you anymore. Two weeks later I received the officer's report assigning blame to the other driver. CYA people, because Werner will throw you under the bus.
  2. ZVar
    ZVar Road Train Member
    Sep 10, 2010
    10,911
    Thanks Received:
    23,830
    Flint, MI
    Werner lost a lawsuit for 90 million when the wreck was 100% the other drivers fault. Do you blame them for being paranoid?
    Opus, QuietStorm and Rubber duck kw Thank this.
  3. Flat Earth Trucker
    Nov 19, 2018
    4,240
    Thanks Received:
    16,035
    I do. The Werner safety team seemed a bit too quick on the draw since it took two weeks for the blame game to be played out.
    Prematurely assigning blame didn't earn Werner a dime of that 90 million back.
  4. Antinomian
    Antinomian Road Train Member
    Feb 17, 2013
    2,137
    Thanks Received:
    3,389
    You still got the preventable. Check your DAC.
    UsualSuspect and x1Heavy Thank this.
  5. kemosabi49
    Jan 13, 2013
    10,901
    Thanks Received:
    47,292
    SW Arkansas
    Yep. I am not saying this applies in your case. But an accident that the other driver was determined to be at fault can still be a preventable accident or your part. Is there something that you reasonably could have done to avoid the accident? If so, it is a preventable, regardless of who is at fault.
    roshea and not4hire Thank this.
  6. Flat Earth Trucker
    Nov 19, 2018
    4,240
    Thanks Received:
    16,035
    That's not fair. :crybaby:
  7. HiLoSapien
    Mar 1, 2017
    167
    Thanks Received:
    324
    It sounds like you're saying blaming their own driver is Werner's way of covering their own ###. The judgement against Werner was overturned. What do you think would have happened if they had charged their driver in that accident? Overturned verdict? No. You're argument makes no sense.
  8. ZVar
    Sep 10, 2010
    10,911
    Thanks Received:
    23,830
    Flint, MI
    Except it hasn't been overturned yet. It's still going on.
    When I posted it was dismissed, I guess that wasn't the end of the case...
