Dash cam install - which wire is always hot?
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by true blue, Feb 4, 2017.
  1. true blue
    true blue Medium Load Member
    Jul 13, 2011
    304
    Thanks Received:
    231
    Harrisburg, NC
    I've got a '97 KW and need to find a constantly hot wire to hook up the dash cam to so it will always be on.
    Anyone know which wire would always be hot when the ignition is off?
  2. 062
    062 Road Train Member
    Oct 20, 2013
    6,209
    Thanks Received:
    33,441
    CB post? If not you'll have to find one in the fuse box.
    flood Thanks this.
  3. dptrucker
    dptrucker Road Train Member
    May 14, 2012
    4,681
    Thanks Received:
    3,197
    adelanto,ca.
    You can check the cigarette lighter outlet
    flood and true blue Thank this.
  4. true blue
    Jul 13, 2011
    304
    Thanks Received:
    231
    Harrisburg, NC
    No CB post on this truck. I wired mine up to the overhead dash, but it's not to a hot-always wire.
  5. true blue
    Jul 13, 2011
    304
    Thanks Received:
    231
    Harrisburg, NC
    Dptrucker, thanks, you would be right.
  6. reverendhandy
    reverendhandy Medium Load Member
    Jan 24, 2017
    309
    Thanks Received:
    401
    Modesto, CA
    I have a dash cam as well.
    The only reason you would want constant power is if you're using the parking monitor, which on most dash cams can be turned off.
    If you use the monitor make sure to go into settings and adjust your sensor, otherwise, everytime you get rocked pretty hard in the wind, truck gets bumped, etc., it will snap a picture and lock the file.
    That can chew up your available memory for recording in loop pretty quick.
    If you don't use the monitor, your cigarette lighter plug will come on when you start the truck and begin recording.
    true blue Thanks this.
  7. Balakov100
    Balakov100 Road Train Member
    May 10, 2012
    3,937
    Thanks Received:
    2,637
    Temple, TX
    I have a 128gig Memory Card in mine. I never shut it off.
    flood Thanks this.
  8. reverendhandy
    Jan 24, 2017
    309
    Thanks Received:
    401
    Modesto, CA
    What kind of dash cam do you have?
    Most of them I looked at online could only go 32g. The one I got can go 64g.
    Don't remember seeing any that could go larger.
  9. Balakov100
    May 10, 2012
    3,937
    Thanks Received:
    2,637
    Temple, TX
    That's ridiculous in 2017.
    I just got a
    Street Guardian SG9665GC v3
    They say up to 200gb.
    Even my old one could take 64 gig Cards.
  10. reverendhandy
    Jan 24, 2017
    309
    Thanks Received:
    401
    Modesto, CA
    Mine has 64g, but I'll look into Street Guardian.
    That name doesn't ring a bell, but definitely worth a look if I can go more than 64.
