detroit 60 series cooling fan not working automatically
Discussion in 'Peterbilt Forum' started by bwilliams, Oct 11, 2014.
  1. bwilliams
    bwilliams Bobtail Member
    Oct 11, 2014
    Thanks Received:
    1996 pete 379 detroit 60 series.
    serviced air conditioner went out for 3 weeks. air not blowing cool. coolant dry. changed dryer, Serviced air conditioner again. now cooling fan not coming on automatically. changed the sensor on the block. no air leaks. fan will come on manually. What else could it be?
  2. Team Sohn
    Team Sohn Bobtail Member
    Sep 27, 2014
    35
    Thanks Received:
    12
    If you're talking about the engine fan, you might want to check your thermostats. Usually those fans are thermostatically controlled and if your thermostats are bad, it could cause your fan to not work properly.
  3. zircon
    zircon Bobtail Member
    Mar 12, 2010
    23
    Thanks Received:
    5
    Austin Texas
    Might check a pressure switch in ac system on firewall driver side. I think this switch is on hi side of ac system and tied to engine fan auto switch Good luck . Zircon
  4. snowwy
    snowwy Road Train Member
    Jul 6, 2009
    20,537
    Thanks Received:
    13,274
    let the truck idle so the engine gets warm. and see if fan comes on while it's sitting. might have to raise the idle as it'll take a long time on low idle. of go climb a hill if you got one close enough that'll heat the truck up.
    what is the normal running temp of the truck as your driving down the road? like mentioned above you could have cold thermostats.
    if your checking for fan on with a/c. that's not going to happen till your high pressure gets high enough. then it'll cycle on and off. if that don't happen, then it's probably the high pressure fan a/c switch.
