digital swr meter
Discussion in 'CB Radio Forum' started by Chuggy, Sep 24, 2012.
  1. Chuggy
    Chuggy Bobtail Member
    May 23, 2010
    Thanks Received:
    Hillsboro Md
    Has any body used the digital swr meter they are selling on ebay.
  2. Old_School1
    Old_School1 Light Load Member
    Apr 7, 2012
    61
    Thanks Received:
    6
    York , PA
    I have used the digital one built into the Uniden BC880... I have also compared it to a external SWR Meter just to see how accurate it was... The digital one seems to be a bit off but not by much.
  3. jessejamesdallas
    Oct 3, 2008
    1,416
    Thanks Received:
    855
    Republic of Texas
    which one? There's several out there...Only one I ever tried was the one sold by Radio Shack...I wasn't very impressed with it either.
  4. M818
    M818 Light Load Member
    Apr 27, 2011
    286
    Thanks Received:
    147
    Dallas, Texas
    I don't care too much for a digital meter in such a crazy spot as CB work where every sort of strange thing can be found. A concern of some oddball RF issue or other thing tricking the meter.
  5. cadillacdude1975
    cadillacdude1975 Road Train Member
    Mar 20, 2010
    1,081
    Thanks Received:
    394
    Chattanooga, TN
    nope. never used one.
  6. MsJamie
    MsJamie Road Train Member
    Sep 11, 2012
    2,368
    Thanks Received:
    1,334
    Somewhere I'd rather not be...
    Personally, I wouldn't bother. A no-name Shenzhen technobauble usually isn't of the highest quality.
    If you want to spend $50-$60 on an SWR/power meter, I'd get this:
    http://www.hamradio.com/detail.cfm?pid=H0-008975
    I know MFJ isn't top quality, but they're pretty good. At least they have a useable warranty.
  7. handlebar
    handlebar Heavy Load Member
    May 28, 2010
    829
    Thanks Received:
    592
    Them Thar Hills, TN, ZIP EIEIO
    For any wattmeter to be accurate, particularly on a radio that's been "tweaked and peaked" to use the vernacular, by someone without the benefit of a spectrum analyzer, it's important to at put a low pass filter inline before the meter. That will at least make sure that the meter isn't reading harmonics pouring out of a radio that's been "tuned for maximum smoke".
    FWIW, if the output is checked both with and without the LP filter inline and a difference is noted, the filter should be left inline while the radio is in use, at least until it gets redone by a better-equipped shop. I've got a full "commercial" bench, and I still run a LP filter on all my gear, just in case something fails in the course of normal operation. It won't stop in-band spurs, but it will stop transmission of most energy on frequencies above the cutoff frequency.
    There are lots out there. MFJ has one that's rated up to 200 watts for about $35: http://www.mfjenterprises.com/Product.php?productid=MFJ-702B
    They've got two more for over 1,000 watts, but the little one will take care of all legal CBs and most exports. Pretty cheap insurance against interference, and a good way to keep your wattmeter (and your shop) honest.
    Hope that helps.
    73,
    Handlebar
  8. Chuggy
    May 23, 2010
    Thanks Received:
    Hillsboro Md
    The meter on ebay is a no name hong kong import.I was just curious to see if any body had used one thank for the replys
  9. Mad Dog 20/20
    Mad Dog 20/20 Heavy Load Member
    Jan 31, 2010
    768
    Thanks Received:
    193
    Skid Row
    With a LPF inline before the meter, most operators would tell you it's faulty and stealing watts.:roll:
  10. WA4GCH
    WA4GCH Road Train Member
    Aug 12, 2009
    3,324
    Thanks Received:
    577
    Seminole Florida
    It IS stealing watts watts that do you no good ......
