Do all previous driving licenses show up on DAC?
Discussion in 'Questions From New Drivers' started by smctransferllc, Jul 7, 2012.
  1. smctransferllc
    smctransferllc Medium Load Member
    Jul 13, 2009
    345
    Thanks Received:
    36
    KC, KS
    When applying to a company, is it possible to omit any previous driving licenses from the application without them seeing it on DAC? Only reason I ask is because I held a Kansas license, moved to Texas for a year and held a license there (that was a class C, no CMV), them moved back to Kansas and reacquired my Class A here. I just recently put on a motorcycle endorsement, so that reset the issue date. When I lived in Texas, I hadn't worked at any employer there that required running a DAC, so I would have thought that license wouldn't be there. That's the license I figured I could omit from the app, and just put down my current Kansas license. I hadn't done anything significant with it other than drive a car, & it wasn't for long. And besides, when they run an MVR on you, they're only going off of your current DL number, correct? I know HR doesn't dig way down. Thanks for the input!
  2. 48Packard
    48Packard Ol' Two-stop Shag!
    Apr 19, 2009
    8,348
    Thanks Received:
    9,871
    Could be anywhere
    Any particular reason you wish to omit this license?
    Most apps I can recall have had wording to the effect of "list ALL licenses held in the last X years".
    That kind of says it all.
  3. NavigatorWife
    NavigatorWife Road Train Member
    Apr 30, 2012
    2,937
    Thanks Received:
    2,080
    Cental West, AL
    I would think with computers nowdays the number and state will come up so you better had report it I do believe.
  4. -MadMax-
    -MadMax- Light Load Member
    Feb 29, 2012
    248
    Thanks Received:
    72
    Pennsylvania
    I'm a big fan of complete honesty.
    ewill71 Thanks this.
  5. bluerider
    bluerider Light Load Member
    May 16, 2012
    246
    Thanks Received:
    208
    Washington, DC
    I've had licenses in 4 states and 3 countries. I hope they don't all show up on DAC.
  6. ChromeDome
    ChromeDome Road Train Member
    Jun 10, 2007
    3,706
    Thanks Received:
    2,086
    Lakeland, FL
    The only thing that shows up on DAC is what trucking company's put on DAC. States do not put anything on it at all, ever.
    When you apply they will ask you to list all states you held a license in. If you fail to list one, and they find it, you will get fired or not hired due to lying on an application.
  7. STexan
    STexan Road Train Member
    Oct 3, 2011
    14,963
    Thanks Received:
    29,154
    Longview, TX
    i don't think DAC would be a concern. There are other record checks in the normal course of today's deeper background checks that some implement that will probably bear this out but I wouldn't worry about this being a problem for you unless there is some activity on that particular state's DL record.
  8. WitchingHour
    WitchingHour Road Train Member
    Apr 1, 2011
    3,424
    Thanks Received:
    2,143
    Broomfield, CO
    It's your MVR that any previous licenses will show up on (US licenses, not foreign ones). If you omit one, and your background check shows that license, there'll be some questions raised.
  9. Elendil
    Elendil Heavy Load Member
    Mar 27, 2011
    921
    Thanks Received:
    626
    Ottawa, IL
    Plus I would think if you listed a previous address in another state for any length of time, but didn't list a license for that state, it might also raise some red flags.
  10. fortycalglock
    fortycalglock Road Train Member
    Jun 25, 2011
    6,153
    Thanks Received:
    6,583
    Tourist Town, FL
    One of the background checks offered by HireRight (DAC) is a search for other licenses. Just list it, as it will pop up, when they check the box for the search.
    123456 Thanks this.
