Do I have to log this?
Discussion in 'Ask An Owner Operator' started by RTR, Aug 16, 2014.
  1. RTR
    RTR Light Load Member
    194
    Thanks Received:
    49
    Alabama
    Got home Thursday night 7 pm. Took truck (Bobtailed) to Gadsden Friday to get overhead run, several other maintenance items. My wife came and got me and I will pick up the Truck Sunday after Church and fuel at the Petro, still Bobtail.
    My question is do I need to log this or no since I am not under a load or dispatched on one?
  2. Aminal
    Aminal Heavy Load Member
    Nov 9, 2013
    749
    Thanks Received:
    1,049
    Hiding in Honduras - OK, Ash Fork, AZ actually ;-)
    The official answer would be yes. You can't use personal conveyance, even though you are not under dispatch and bobtail, if you are taking it to have work done on it. That'd be drive line time. Naturally your off time is still off time. This would be what the DOT will tell you. What you do is your business. ;-)
  3. skateboardman
    skateboardman Road Train Member
    Jan 14, 2012
    6,232
    Thanks Received:
    5,706
    flatbed heaven
    not necessarily true, it depends on who owns the truck. he isn't under dispatch, is bobtail and doing it for personal use if he owns it. I myself have logged things like that off duty, I have even flagged fuel stops as off duty while on personal conveyance and never had the log dept question it.
    but then I own both truck and trailer and am leased to a carrier
  4. Powder Joints
    Sep 25, 2007
    7,687
    Thanks Received:
    7,782
    Rosamond, SoCal
    If its your truck I would log it as off duty. If its there truck I wouold log it as on duty and turn in a bill for the time.
  5. baha
    baha Road Train Member
    Jul 25, 2013
    4,137
    Thanks Received:
    2,836
    ga
    Dont buy fuel if plan on using the 34 hr restart over your weekend off.
    Victor_V and Cranky Yankee Thank this.
  6. skateboardman
    Jan 14, 2012
    6,232
    Thanks Received:
    5,706
    flatbed heaven
    its fine, just flag it as personal conveyance, no difference thatn buying gas for the car in that case
  7. Victor_V
    Victor_V Road Train Member
    Dec 15, 2008
    2,797
    Thanks Received:
    1,494
    Spencer, Indiana
    I wouldn't log it. As far as I'm concerned, if you're not 'under load' and off duty (bobtailing), you're off duty. DOT wants you 'on duty' during breakdowns, for example... Well, you're under load, right?
    Are routine repairs breakdowns? No, I don't think so. But if you're a company driver and required to take truck over to Cummins, you're 'on duty' during that time.
    For a Haz outfit, when we went out of town (which was all the time), we logged regular. When doing little stuff in town (Indy) we just logged it 'on duty' because of the many starts and stops.
    Figure an EOBR will typically give you 2 miles before it kicks you into 'driving'. Mine did. So I give myself the same leeway with my paper logs. If I bobtail 30 miles home instead of leave truck in yard, I don't bother log it, just make sure my last change of duty went to 'off duty'. If I clean up, wash truck or make some repairs do I log 'on duty'? No-o-o-o-o. I'm not under load.
    Now if there's a problem, you hit something, something hits you to or from repair shop, maybe some would then fetch the magic eraser... Dunno. For me, if I'm not responsible for moving a load, I'm off duty. Suppose could very well be different for someone else, different situation.
  8. bigdogpile
    bigdogpile Road Train Member
    May 16, 2010
    1,931
    Thanks Received:
    1,463
    fontana ca
    I guess the Do I,Dont I argument is as old as the logbook rules.
  9. Snowshoes
    Snowshoes Heavy Load Member
    Sep 23, 2012
    878
    Thanks Received:
    664
    Pleasant Grove, Utah
    With the last two companies I drove for you can do that and log it off duty driving (You can do that for 30 minutes). Unless things have changed in the past year. If I remember correctly whe I first started they would let us take our truck to a restaurant if we bobtailed and we did not have to log it, that was in 2007
  10. RTR
    194
    Thanks Received:
    49
    Alabama
    It is my Truck and Trailer and I am not leased on with anyone, running under my own authority. So in reality I do not have to show this if I am not under a load correct? (I will not be under a load until Monday Morning around 10 am est. I did fuel on the way home though, but did not spend over 10 minutes doing this, so not sure about that?
