Do I need three batteries?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Bdog, Mar 12, 2016.
  1. Bdog
    Bdog Road Train Member
    Nov 6, 2014
    1,057
    Thanks Received:
    877
    I have a W900 dump truck with a M11. It has three batteries and they are shot.
    I don't use this truck very often and it is ALWAYS parked at my shop and plugged into a battery tender when not in use. I never use it when it is below freezing. Do I really need three batteries for it in this scenario or would two do?
  2. AModelCat
    29,059
    Thanks Received:
    156,981
    I prefer to use 4 myself but you might get by with 2 high CCA batteries on an M11 if you're leaving it on charge when not in use. My advice is if its got 3, leave it that way. Never hurts to have extra juice.
  3. ShooterK2
    ShooterK2 Road Train Member
    Dec 14, 2012
    5,533
    Thanks Received:
    89,470
    Oklahoma
    When I bought my '99 W9, it only had two batteries. Never had trouble starting the N14, but it was warm weather. I added another battery before cold set in, just to make me feel better.
  4. Pedigreed Bulldog
    May 7, 2011
    7,737
    Thanks Received:
    14,421
    I had a battery explode when I hit the key after fueling a few years ago. Disconnected the bad battery, fired it up, and ran the rest of the day on the other 2.
    ...So yes, 2 will be plenty. Heck, you may even be able to get by with only 1 if it'll turn the motor. If you go THAT route, though, I wouldn't shut 'er down anywhere you don't have access to additional juice to get 'er fired back up again if that 1 battery isn't at 100%.
  5. BoxCarKidd
    BoxCarKidd Road Train Member
    Aug 26, 2014
    4,436
    Thanks Received:
    6,472
    If I remember correctly the CCA rule of thumb minimum is 150 CCA per 100 CID on gas engines and 300 CCA per 100 CID for diesels. At 61 cubic inches per liter an M11 is around 670 cubic inches and should have around 2000 CCA battery capacity. I do not remember who's rule or thumb that was but it does not care how many batteries are used.
    Rather than try to get by with less CCA I would consider automotive batteries. They are not designed for service like commercial batteries. Ten hour per day operation, constant vibration, shock, etc.. However 1000 CCA is still 1000 CCA. Three 750's equal 2250 CCA, may not cost more than two 1000 CCA's and have more reserve capacity.
    Your starter and cables will thank you and you will thank them if you ever choke it down in an intersection.
  6. Caterpillar Cowboy
    Caterpillar Cowboy Heavy Load Member
    Nov 11, 2010
    837
    Thanks Received:
    607
    Wyoming
    You could put two in it, but if you've got my luck something's going to come up where it can't be plugged into the battery tender, and / or you will have to start running the truck when it's cold out.
    Some of mine have 3, some have 4.
  7. Bdog
    Nov 6, 2014
    1,057
    Thanks Received:
    877
    Thanks for the replies. I guess I was just trying to be cheap. We haven't been using this old girl much lately. I think it has hauled one load since Halloween. Just was trying to avoid spending a lot on batteries that will probably go bad from time before use.
  8. A21CAV
    A21CAV Road Train Member
    Oct 4, 2011
    1,848
    Thanks Received:
    2,156
    Laredo, TX
    How about getting batteries that are dry with the acid in a separate container like the old days and fill and install the batteries when you need them . Unlimited shelf life and if you retire that truck you'll have them for another .
  9. beemergary
    beemergary Light Load Member
    Apr 11, 2014
    229
    Thanks Received:
    112
    Get three batteries--your starter will thank you.
    A21CAV Thanks this.
  10. Ozdriver
    Ozdriver Heavy Load Member
    Oct 16, 2015
    767
    Thanks Received:
    1,390
    Australia
    If you are using a battery tender new batteries should last just about forever.
