Do you get to choose your loads?
Discussion in 'Questions From New Drivers' started by Montgomery, Oct 15, 2012.
  1. Montgomery
    Montgomery Light Load Member
    Sep 5, 2012
    120
    Thanks Received:
    27
    Virginia
    Do you get to choose the loads you take? How does it work?
    snowwy Thanks this.
  2. Lilbit
    Lilbit Road Train Member
    Aug 4, 2008
    16,583
    Thanks Received:
    12,232
    Let me check my logbook
    Montgomery and airforcetoo Thank this.
  3. Arial
    Arial Light Load Member
    Sep 11, 2012
    73
    Thanks Received:
    33
    California
    Yes what Lilbit said, but your title for this tread was such a leading question I had to respond. :biggrin_2559:
  4. passingthru69
    Jul 12, 2009
    8,740
    Thanks Received:
    34,849
    davenport,Ia / ratchaburi, thailand
    Depends. If owner op. most of the times yes.
    Most companies will make their drivers take the ld. given them, unless you are one that bumps your head under somebodies desk..
    I still have a full head of hair...:biggrin_2558:
    Montgomery Thanks this.
  5. FozzyNOK
    FozzyNOK Road Train Member
    Jul 18, 2007
    2,459
    Thanks Received:
    3,786
    Oklahomistan
    The way it sort of works for the most part (forced dispatch) is that there is a pool of available loads and a pool of trucks in an area. As drivers come available (empty) and depending on the load appointments, drivers available hours to deliver loads, their home time requirements etc or if applicable drivers who refuse loads (duh). the loads are dispatched to the trucks on that basis on a first empty first served. The best thing that drivers can do is take whatever comes to them and run with it.
    Montgomery and NavigatorWife Thank this.
  6. carrkool
    carrkool Heavy Load Member
    May 10, 2012
    883
    Thanks Received:
    495
    adah, pa
    it all depends no one can give a straight response to this. its different with every company. some are forced dispatch some you can refuse a load as a company driver. now as a o/o you can always so no but might lose your job. than if you get your own truck trailer and authority or lease with a company that lets you find your own frieght than its a whole new world. in that world you have to look at what a load pays how many miles empty and loaded what its going to cost you to run it and so on and so on. you look at many different load boards and keep calling and working out a final price and take a load.
  7. Mountain Hummingbird
    Mountain Hummingbird Medium Load Member
    Oct 14, 2012
    601
    Thanks Received:
    399
    Well yes and no you can refuse a load with reason, otherwise you take what you get. If you own your own truck you can usually find a way out of a load you do not want like something to be checked on your truck first.
  8. buno1982
    buno1982 Light Load Member
    Apr 21, 2012
    54
    Thanks Received:
    20
    New London, CT
    if your a company driver 99% of the time you have to take what they give you,,if your an owner op you have a choice its your truck
  9. Mountain Hummingbird
    Oct 14, 2012
    601
    Thanks Received:
    399
    Is that not what I said ?
  10. T...Street
    T...Street Light Load Member
    Aug 19, 2012
    182
    Thanks Received:
    176
    randolph co. NC
    Or if you are in the foodservice part, you usually have a regular run. same customers 2 to 3 three times a week. Lot of variables to be considered in your question...but it is a good one to ask, may help you decide which type of trucking you want to do after your experience level goes up affording you some different choices.
