Does your automatic transmission ever quit on you right when you're coming out of a stop at a light?
Discussion in 'Questions From New Drivers' started by A Bug, May 19, 2020.
  1. A Bug
    A Bug Heavy Load Member
    Mar 15, 2014
    905
    Thanks Received:
    1,818
    Sevierville TN
    I really hate Def
    I've been driving this automatic Mack for about 6 months now. I'm finally getting used to the thing except more than once now when the light turns green and I start to move, the transmission will just slip out of gear and leave me stranded in the intersection for about 10 seconds before it allows me to get back in gear and keep moving.
    This only happens after starting from a complete stop, and only when it tries to upshift from the first gear from that complete stop.
  2. Voodoo Pyg
    Voodoo Pyg Oink! Oink!
    Jan 25, 2015
    570
    Thanks Received:
    669
    Corpus Christi, Texas
    My Peterbilt did the same thing or just froze in general.
    LoSt_AgAiN Thanks this.
  3. Lazer
    Lazer Road Train Member
    Jan 22, 2017
    1,791
    Thanks Received:
    2,850
    That’s the new normal, just a slight mil-second voltage spike from the alternator will leave you dead in the water, at an intersection, RR crossing, etc. It happened to me more than once, with different trucks.
    Have also had the shift box on top of the transmission puke out on me.
    Rubber duck kw Thanks this.
  4. AModelCat
    29,209
    Thanks Received:
    159,156
    Good old 18 speed Roadranger. As dependable as it gets.
    LTL Bull, baha, Rubber duck kw and 3 others Thank this.
  5. Brandt
    Brandt Road Train Member
    Sep 17, 2012
    4,506
    Thanks Received:
    6,169
    The Detroit DT-12 transmission don't do that. It turns on the engine brake between gears in low range to kinda help it shift. Maybe so it doesn't miss gears when it skip shifts
  6. tscottme
    tscottme Road Train Member
    Jul 25, 2008
    14,290
    Thanks Received:
    27,476
    Somewhere out West, in my mind.
    My truck does something like that when it decides to start moving in too high of a gear. When I'm loaded I gross 78-79k. Sometimes the tranny selects 3rd to start. When I stop and it's in 3rd I downshift to 2 or 1, depending on conditions. If I don't and the starting gear is too high I will start moving and the tranny will downshift and itbtakes a few seconds for it to resume moving. It sometimes feels like 2 lifetimes before it starts moving.
    Make sure starting gear is appropriate for conditions like weight & up/down hill, etc.
  7. MGE Dawn
    MGE Dawn Road Train Member
    May 19, 2019
    1,096
    Thanks Received:
    2,285
    Vancouver, WA
    ####, today I learned. Never really put any thought into how the truck could consistently skip from 1st to 4th without any sort of hangups...
  8. D.Tibbitt
    21,750
    Thanks Received:
    148,678
    I had a dt12 that used to drop out of gear when it got real cold. Always 7th gear. Pain in the butt. Stick shift will always be king
    Rubber duck kw and MACK E-6 Thank this.
  9. Espressolane
    17,547
    Thanks Received:
    107,493
    Have run a DT-12 for a while. None of them have done this. Wonder if it is a parameter setting. If so, that function was not set on my truck.
  10. Brandt
    Sep 17, 2012
    4,506
    Thanks Received:
    6,169
    It depends on how much power you want and the gear your in. The two DT-12 I have driven do it. In first gear put pedal to the floor. The RPMs will go to like 1700 to shift. If you listen you can hear the engine brake come on when it's between gears.
