Don't know what I'm doing need HELP!
Discussion in 'Ask An Owner Operator' started by Los, Jan 19, 2016.
  1. Los
    Los Bobtail Member
    Jan 19, 2016
    Thanks Received:
    Want to buy a tractor. Got $25k to spend. Don't really know what to look for. Miles? Year? Make? Trying to go through the ports. I found this one but I don't know anything about tractors. Been working for a big time food distributor for 3+ years. Tired of humping boxes.
    2007 VOLVO TANDEM AXLE DAYCAB IN PS, VNM64T200. FRESH DOT INSPECTION, NEW REAR JUST INSTALLED. FUEL SAVING VOLVO VED-12 453 HP ENGINE, FULLER FRO-145210C 10 SPEED MANUAL, 3.73 REARS, ALUMINUM FRONTS WITH STEEL REARS. 12,500 LBS FRONT AXLE, 40,000 LBS
  2. Allow Me.
    May 28, 2009
    10,689
    Thanks Received:
    12,290
    Rancho Mirage, Ca.
    :hello2:You better be a gamblin' man....any used truck is a crapshoot. Good luck
    Puppage and Los Thank this.
  3. Crossroads
    Crossroads Light Load Member
    Feb 28, 2013
    239
    Thanks Received:
    236
    Lumberton NC
    Not dissing you here but if you are asking a question like that sounds like you may not be ready to buy a truck. Are you going to run under your own authority or someone else's? Do you have reliable source of revenue? Then there's insurance, your base plate, and probably a bunch more stuff I am missing.
    Not trying to discourage you, but before even considering buying a truck you really need to have a business plan in place. I worked as an auto mechanic and have and driven for years, but before I bought a truck I would pay to have a DOT truck mechanic go over it.
    Dye Guardian and Ruthless Thank this.
  4. RustyBolt
    RustyBolt Road Train Member
    Feb 21, 2015
    2,073
    Thanks Received:
    3,333
    Bement, IL
    Hell, ANY truck is a crap shoot. Used or new. The warranty will eventually run out on a new truck. And in some cases, you'll lose more money waiting for warranty work to be completed than had you bought the parts and did it yourself. Just saying.
    @Los save more money. That's a good down payment. But you'll need a break down fund of $10K or more set aside too. I would suggest $20k in reserve. While you save more, learn as much as you can about the different trucks that are out there. Issues different engines are known for. How one truck may be better suited for flat bed while another is better for vans. Etc. Etc. Then you can make a better informed decision when the time comes.
  5. tucker
    tucker Road Train Member
    Jun 13, 2008
    12,647
    Thanks Received:
    40,423
    IN
    Crossroads Thanks this.
  6. rocknroll81
    rocknroll81 Road Train Member
    Sep 29, 2010
    1,363
    Thanks Received:
    1,005
    West Allis Wi.
    Just wondering, are you going to do local driving? If not why are you buying a day cab
  7. Crossroads
    Feb 28, 2013
    239
    Thanks Received:
    236
    Lumberton NC
    +1 And only have to work one job, instead of two.
  8. Crossroads
    Feb 28, 2013
    239
    Thanks Received:
    236
    Lumberton NC
  9. haycarter
    haycarter Road Train Member
    Jun 9, 2012
    1,920
    Thanks Received:
    5,317
    Australia
    I could be wrong But I think the Op wants carts Containers from the Ports.
    rocknroll81 Thanks this.
  10. Los
    Los Bobtail Member
    Jan 19, 2016
    Thanks Received:
    Thanks. I appreciate the comments. What's a base plate? Only need a day can to run out of the ports
