DOT physic...will I be able to pass or am I out of luck?
Discussion in 'Questions From New Drivers' started by Daniel17452, Jul 2, 2014.
  1. Daniel17452
    Daniel17452 Bobtail Member
    Jun 21, 2014
    8
    Thanks Received:
    So, I have some bad news since I was last on here. At my prior job I was hurt because of inadequate safety equipment. I was having to help lift 300 lb. Railroad ties and wound up getting hurt.
    I hurt my back, which has finally cleared up, but was out of work for a little while. A little after the first work comp meeting, they discovered that it had wound up giving me a small inguinal hernia.
    Here's the thing, my back isn't bothering me at all anymore, and I have full range of motion even with the hernia. Once I get that fixed, will I be able to get my CDL or am I just screwed.
    Thanks for the help.
  2. crankyazz
    crankyazz Light Load Member
    Aug 4, 2011
    173
    Thanks Received:
    38
    Fountain, Co
    U should be able to get cdl just fine once your better.
  3. Hamburger71
    Hamburger71 Medium Load Member
    Jun 18, 2014
    349
    Thanks Received:
    235
    North Carolina
    If you have recovered, it should be no problem.
  4. cnsper
    cnsper Road Train Member
    Feb 28, 2014
    5,869
    Thanks Received:
    27,421
    Hell I got mine with a hernia. As long as it does not affect you, you are good to go.
  5. Powder Joints
    Sep 25, 2007
    7,663
    Thanks Received:
    7,744
    Rosamond, SoCal
    No problem, drivers get hurt, and come back, part of life.
  6. Brandson
    Brandson Medium Load Member
    Dec 14, 2013
    667
    Thanks Received:
    481
    Heres a clue for ya. They have handicapped truck parking spots.
    HotH2o and ewill71 Thank this.
  7. ewill71
    ewill71 Heavy Load Member
    Oct 3, 2011
    759
    Thanks Received:
    234
    mcgregor tx
    if you can pass the physical then you have no worries.
  8. superflow
    superflow Road Train Member
    Jan 2, 2014
    2,038
    Thanks Received:
    1,870
    The doctor will have you bend over and touch your ankles ,he might press on your spine asking if anything hurts or have you twist alittle bit ....if you can touch your ankles &twist .....youre good to go !
  9. Scott101
    Scott101 Medium Load Member
    Nov 30, 2008
    607
    Thanks Received:
    407
    NorCal
    You should be ok either way. If you want to fix it first, great. If you want to certify with the hernia you should probably be ok too.
    As long as it doesn't cause discomfort, or interfere with the safe operation of the vehicle, you can be certified.
    https://nrcme.fmcsa.dot.gov/mehandbook/other_hernias_ep.aspx
    I just re certified last week. I used an examiner of the opposite sex and didn't so much as have to take my shirt off. She did "check" for hernias... I guess. While laying on the exam table she slid her finger tips down my pants a couple inches below my waist line and had me lift my feet up off the table 6" while she was feeling my abdomen. She didn't ask if I had a hernia, and checked "No" on the long form next to hernias. --And this was under the new registered examiners rules.
    The questions you answer on the long form doesn't even ask if you have a hernia. I guess it is up to them to find it.
    My advice is don't lie if asked, but don't volunteer any information that doesn't affect the safe operation of a commercial motor vehicle. And use an examiner of the opposite sex. It has been my experience the exams are less intrusive. You should be certified even with the hernia, but if you can get "No" checked off next to the hernia question, all the better.
  10. Dagger
    Dagger Light Load Member
    Mar 17, 2012
    164
    Thanks Received:
    87
    You can get certified. My wife passed her physical with a huge hernia near her belly button. Just try to keep it off any paperwork. Her boss told her, off the record, that some employers will consider her a "walking workman's comp case" so she shouldn't mention it unless she absolutely has to.
    If you get it fixed before you try to get hired you should be ok.
