Dropping a Loaded Tanker
Discussion in 'Tanker, Bulk and Dump Trucking Forum' started by hotpotato13, Jan 24, 2014.
  1. hotpotato13
    hotpotato13 Bobtail Member
    Mar 13, 2013
    Thanks Received:
    Sometimes we have to drop a loaded cement tanker on the yard because the customer can't take it yet. I'm worried about the stress this puts on the landing gear. Any suggestions about how to better support an unhooked load?
    First time posting... this forum has been a great resource for me, so thank you all!
  2. rbrtwbstr
    rbrtwbstr Road Train Member
    Jul 11, 2012
    3,374
    Thanks Received:
    7,785
    in the bush somewhere
    We do it quite often. Dump the trailer suspension and tractor suspension before unhooking. That's about all you can do
  3. luvtotruck
    luvtotruck Road Train Member
    Jul 30, 2013
    1,978
    Thanks Received:
    1,161
    Phoenix Arizona
    Drop it lightly on level ground! making sure the legs are as far down as they will go to not seem as if it is being dropped on them. The dropping all that weight is what is bad on them, they are built to handle the weight just not being dropped on it. Enjoy the Forum, There is plenty of knowledge to be had here!. If you have any questions, feel free to ask, I don't know much but what I know is what I know! :)
  4. Dieselgeek
    Dieselgeek Medium Load Member
    Nov 25, 2012
    427
    Thanks Received:
    209
    Minnesota
    My company will not drop a loaded tanker without a wrecker supporting itÂ… So needless to say, we only drop a loaded trailer if a truck breaks, and can have another tractor back under...
  5. GasHauler
    Oct 23, 2005
    6,257
    Thanks Received:
    4,365
    Vegas/Jersey
    Being a gas hauler I have a different question. Is it just cement or mixed concrete? If it's concrete, what do you do with the concrete? Is the trailer only there for a little while? Coming out of the Navy Seabees I was involved in a lot of pours and I would question the integrity of the mud. If it's just cement and you're waiting to blow it off why would it be different than any other load? We've dropped loaded gasoline trailers before and there's no concern at all.
  6. Saddletramp1200
    Saddletramp1200 Road Train Member
    Sep 4, 2011
    2,111
    Thanks Received:
    2,836
    Houston Texas,USA
    Drop it on dirt. Landing gear will hold it. Drop it on concrete is best. Don't forget those little hoses. :)
  7. Saddletramp1200
    Sep 4, 2011
    2,111
    Thanks Received:
    2,836
    Houston Texas,USA
    O , For those that should not be pulling a tanker anyway. Let the load stop moving before you pull out from it. 10:00 is Best. 5 minutes is good.
  8. wesland24
    wesland24 Medium Load Member
    Dec 15, 2006
    339
    Thanks Received:
    152
    Macon,GA
    Don't think a loaded cement tanker is going to have much surge to it
    Big Duker and sculptor Thank this.
  9. KW Cajun
    KW Cajun Road Train Member
    Apr 12, 2013
    2,383
    Thanks Received:
    3,652
    Copperhead Road
    I'm not the OP but can assure you it's not concrete mix or any grout slurry.
    Once the cement powder in concrete or grout hyrates (mixes with water), the clock is ticking, and it typically is unusable once it is 2 to 3 hrs old, max.
    Certain admixtures can extend this time, but not by a great deal. If you try to use it beyond it's "freshness", it will only result in microcracking, poor bond, and many other severe negatives, even at early stages of "staleness".
  10. GasHauler
    Oct 23, 2005
    6,257
    Thanks Received:
    4,365
    Vegas/Jersey
    That's what I though. Just like asphalt you've got so much time and rpm's on the mix. We would allow a 6" slump if we were training with new guys and it was only a sidewalk but when we had very strict pours sometimes with a 7500 psi strength we watched it very closely. Like a runway, but then we were using our slip form paver and if it got put down wrong it came back up. It was all for training in case of war.
