Eaton Fuller 13 spd making noise
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Wildcat74, Oct 3, 2011.
  1. Wildcat74
    Wildcat74 Medium Load Member
    Jul 15, 2008
    354
    Thanks Received:
    128
    Omaha, NE
    So in March of last year my 13 spd took a dump on me and I had it replaced with a remanned 13 spd. Now I am getting noise when I'm in high range and I split up, especially in what I guess would be 11th gear (all the way right and forward in Hi transfer and split up). I've called the shop to talk to the guy who put in the reman and he got the information and said he would check his manuals and call me back, have yet to hear from him. I crawled under the truck and checked the oil in the trans and it was about 1/2 gallon low so I filled it up. I'll be driving the truck again tomorrow so I'll know then if that fixes it but I was wondering if maybe there was someone here who knows what it could be with this description? I really don't want to be faced with another transmission bill but I want to get this nipped in the bud. Thanks in advance.
  2. 07-379Pete
    07-379Pete Crusty Commando-Pete
    Oct 3, 2008
    2,549
    Thanks Received:
    2,347
    Campbellsville, Ky
    Is the noise happen while your in a pull or in a coast like going down hill?
    Beings its a reman and if it was gone thru right with a new bearing kit it should not be giving problems. It vary well could be the power divider or rear end it self.
  3. Wildcat74
    Jul 15, 2008
    354
    Thanks Received:
    128
    Omaha, NE
    Mostly under a pull. Rear end is newly rebuilt and this problem was going on before and after it was rebuilt as well.
  4. bender
    bender Road Train Member
    Jul 20, 2010
    2,105
    Thanks Received:
    1,356
    Don't Kid Yourself
    Are any unusual noises present in any gears in high range direct or just the 11th split?
  5. Wildcat74
    Jul 15, 2008
    354
    Thanks Received:
    128
    Omaha, NE
    It's only when I'm splitting up but I have noticed that shifting seems to be getting a little more tough in all gears now.
    Rickylexy and freightliner438 Thank this.
  6. logtrucker25
    logtrucker25 Light Load Member
    Jul 27, 2009
    70
    Thanks Received:
    9
    northern CA
    Maybe it got to hot and wore some bearings cuz the oils been low?
  7. bender
    Jul 20, 2010
    2,105
    Thanks Received:
    1,356
    Don't Kid Yourself
    Sounds like a problem with the mainshaft, too much end play, bearing failure or possibly gear spacer/snap ring failure.
  8. Wildcat74
    Jul 15, 2008
    354
    Thanks Received:
    128
    Omaha, NE
    Tranny temp has never been over about 140
  9. 7122894003481
    7122894003481 Bobtail Member
    Sep 6, 2011
    Thanks Received:
    1,996
    "Could you describe the ruckus, sir?"
  10. bender
    Jul 20, 2010
    2,105
    Thanks Received:
    1,356
    Don't Kid Yourself
    You could pull the drain plug and check for metal, might give you more insight on what's going on.
