engine brake problem on D12c
Discussion in 'Volvo Forum' started by summit trucking, Aug 2, 2013.
  1. summit trucking
    summit trucking Bobtail Member
    Aug 2, 2013
    9
    Thanks Received:
    does anybody know what can cause both engine brakes not to work?
    ithey worked until i parked it for about 24 hours, and it stopped working after that/ i have gone through the entire harness, and 12 volts does get to the solenoid, but when i jump a negative wire straight from the battery to the solenoid i can hear it clicking. both the the EPG and compression braking stopped working.
    took it to the volvo dealership in town and they cant figure it out either, but according to the guys here the mechanics at the volvo are just street mechanics that dont know jack
    any ideas?
  2. Pablo-UA
    Pablo-UA Road Train Member
    Oct 11, 2010
    7,604
    Thanks Received:
    1,642
    Borispol, Ukraine
    stuck clutch ore brake pedal switch, use VECU inputs test for sure
  3. summit trucking
    Aug 2, 2013
    9
    Thanks Received:
    if it were that my cruise control wouldnt work. but it still works. i forgot to mention that
  4. high_roller_302
    high_roller_302 Bobtail Member
    Feb 9, 2012
    28
    Thanks Received:
    20
    Canada
    Could be TPS/IVS. If anything off >6% or idle validation is seen, won`t engage.
  5. high_roller_302
    Feb 9, 2012
    28
    Thanks Received:
    20
    Canada
    Knowing wheather or not the engine goes into warmhold would help diag. If it does, pretty certain the TPS is good. Are there ABS/TCS faults? With some codes from the WABCO system, the engine brake will not operate.
  6. summit trucking
    Aug 2, 2013
    9
    Thanks Received:
    i will check codes when it comes back. i dont have any computer diagnostic tools also. so i either go off what the onboard computer says or just find the wiring problem (which is usually is, not always)
  7. summit trucking
    Aug 2, 2013
    9
    Thanks Received:
    bought a new wiring harness and that fixed it. i found 2 or 3 shorted wires for the engine brake behind the plastic wiring casing. il probably just fix those and have a spare harness
  8. VolvoTech0816
    VolvoTech0816 Bobtail Member
    Aug 4, 2013
    39
    Thanks Received:
    8
    it has to be in the engine harness, I would recommend to replace it
  9. summit trucking
    Aug 2, 2013
    9
    Thanks Received:
    i just said i replaced the harness.....
  10. waltherz
    waltherz Light Load Member
    Dec 12, 2012
    133
    Thanks Received:
    13
    How much did you pay for that harness?
