Engine fan starts without any reason dd15
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by tanveer702, Dec 29, 2022.
  1. tanveer702
    tanveer702 Bobtail Member
    Dec 22, 2018
    12
    Thanks Received:
    Cascadia 2014 DD15, engine fan starts wirhout any reason, truck operates at normal temperature. Usually during winter up here in Canada, fan never comes on. But this winter something is different, replaced the fan clutch in march 2022, and got the solenoid checked, everything seems alright. Is there anything to be checked or someone knows anything about it. Thanks
  2. shatteredsquare
    shatteredsquare Road Train Member
    May 23, 2014
    1,404
    Thanks Received:
    1,836
    middle dirt
    I always drive with the AC comp off unless I need it for something, whenever I turn the AC comp on or use the defrost the fan always comes on automatically even if it's bls cold outside, 2017 DD13 Cascadia Evo
  3. Magoo1968
    Magoo1968 Road Train Member
    Mar 18, 2021
    2,050
    Thanks Received:
    5,466
    St Malo mb
    Parksmart system caused my 2015 to kick fan on in winter . That truck annoyed me until I started shutting rear fan off . Then it was normal until it got really cold and I needed to use bunk heat again.
  4. beastr123
    beastr123 Road Train Member
    Jan 2, 2014
    2,919
    Thanks Received:
    23,911
    Moose Jaw SK CAN
    your A/C is automatically on when you have defrost on so that the air going onto the windshield is dehumidified. The A/C also controls the fan to keep pressures down in the compressor.
    When parked and running move the heater control to vent or floor to stop cycling the fan by the A/C system.
    If you are using a winter-front open it up a bit more while moving and close up when parked.
    singlescrewshaker Thanks this.
  5. HoneyBadger67
    Dec 15, 2018
    2,056
    Thanks Received:
    4,512
    Savannah, TN
    Maybe a dumb question, but do you look at your air gauges when it comes on? My engine fan will automatically come on when air pressure is below 90psi until it gets to 100 again.
  6. tanveer702
    Dec 22, 2018
    12
    Thanks Received:
    Thanku, I'll keep doing that and see what happens.
  7. tanveer702
    Dec 22, 2018
    12
    Thanks Received:
    Yes i am looking at my guages, and if the air is dropping upto 90 psi i would have a different question.
    Rideandrepair Thanks this.
