Fan won’t shut off on a C15 cat
Discussion in 'Peterbilt Forum' started by Perchie15, Jan 7, 2022.
  1. Perchie15
    Perchie15 Light Load Member
    Aug 16, 2021
    237
    Thanks Received:
    71
    Acert engine. Engine fan wont shut off. So engine stays cold! Its not the fan solenoid cuz I put power to it and fan shuts off but I’m not getting power to the fan solenoid. So what would I do next? TIA
  2. Don379
    Don379 Heavy Load Member
    Jan 7, 2021
    714
    Thanks Received:
    1,286
    Ok so you arent getting power to the solenoid. only possible thing is 2 things imo. You have a break in that harness from that solenoid to the ecm. Or the ecm is an issue. First thing to do is get the wire diagram for your engine. Every truck owner should have a cat manual for their engine on cd. They are like 20 bucks on ebay. SO with the wire diagram, find that lead from the solenoid to the ecm pins and check the voltage at that pin to see if its putting out the voltage you need to fire that soleoid. Yes its very easy to do. But you already said you power power to it and shuts the fan off, so im gonna say that wire is bad in the harness. But worse case scenario, your computer has issues. I recommend buying cat comm adapter and free et download so you can see if the ecm is trying to work. Where are you located
  3. Star Rider
    Star Rider Road Train Member
    Sep 23, 2019
    1,640
    Thanks Received:
    14,548
    Plug it in to Cat E/T , A/C high pressure switch , bad intake manifold temp sensor , etc, can cause the fan to run all the time
  4. Troy_
    Troy_ Road Train Member
    Dec 13, 2017
    1,074
    Thanks Received:
    7,409
    Roma, Alberta.
    try unplugging your a/c compressor. or just pull the a/c fuse and see if it stops
  5. Perchie15
    Aug 16, 2021
    237
    Thanks Received:
    71
    I’m in Alberta CANADA.
    How would I see if ECM is working properly like if all the voltages are there or? I do have access to a computer but haven’t went that far to hooking it up
  6. Perchie15
    Aug 16, 2021
    237
    Thanks Received:
    71
    Also the low pressure sensor to?
  7. Don379
    Jan 7, 2021
    714
    Thanks Received:
    1,286
    If you were close to philly pa i was gonna link up with you and scan your ecm with cat et
  8. Perchie15
    Aug 16, 2021
    237
    Thanks Received:
    71
    I managed to get the link up the ecm to my cat what am I looking for though?
  9. bad-luck
    bad-luck Road Train Member
    Nov 16, 2013
    3,359
    Thanks Received:
    6,210
    Baltimore, Maryland
    Had a similar issue with a 3406e, was the atmospheric pressure sensor.
    maconhadalata Thanks this.
  10. Perchie15
    Aug 16, 2021
    237
    Thanks Received:
    71
    God I wish. I just tried jumping the hi pressure sensor and no luck
