fault codes 05 ism
Discussion in 'International Forum' started by fireman5523, Jun 26, 2014.
  1. fireman5523
    fireman5523 Light Load Member
    Feb 12, 2012
    141
    Thanks Received:
    106
    Little Rock, Arkansas
    Hello, my 05 intl paystar, with cummins ism is showing two fault codes
    128:F02
    PID084_P
    And
    128:F00
    PID156_P
    Engine warning light comes on sometimes when climbing a hill, but goes right back out after 2-3 seconds.
    Any clue what's wrong?
  2. chalupa
    chalupa Road Train Member
    Jul 22, 2010
    3,757
    Thanks Received:
    1,643
    Houston,Texas
    156 is fuel timing...if its running it will go away. I got mine by pulling the ECM fuse to prevent unauthorized movement and they tried to crank it. Dunno 084......
    Yellow warn light is an idiot light. Either coolant was low, oil pressure dropped, oil pump bad or connector is loose at sensor which is located on the left front of the engine. Make sure the plug is pushed all the way on and the harness is supported.
    Radiator caps are bad on these trucks, the 6.0 diesel Ford and several others. It's the cap that twists and clicks like a gas cap. If it's old, replace it....under $10
    Also check that cluster of wires to a connector off the battery. If they're corroded the ECM won't get proper voltage and you'll get all this BS and more.
    Good luck
    fireman5523 Thanks this.
  3. fireman5523
    Feb 12, 2012
    141
    Thanks Received:
    106
    Awesome, thanks man!
