Finished training in a automatic and trap in a manual
Discussion in 'Motor Carrier Questions - The Inside Scoop' started by C.S.T, Feb 25, 2018.
  1. C.S.T
    C.S.T Light Load Member
    Nov 15, 2017
    149
    Thanks Received:
    65
    I been train to shift a 10 speed during my course of 4 weeks of School. Then I went on the road with a trainer for 7 weeks in a automatic. I finished my 7 weeks and been assigned to a manual 10 speed. I drove the truck home for the weekend and I get back on the road Monday. I question is when going uphill going 65mph (10) gear, do I need to wait till the rpm drop and the speed is at 45 to downshift to 9 gear while going uphill?
    MysticHZ Thanks this.
  2. 201
    201 Road Train Member
    Apr 16, 2014
    12,321
    Thanks Received:
    25,196
    high plains colorado
    Oh, oh, panic in Detroit. Depends on the hill, 45 is a little low if you still have a ways to go uphill. I'd downshift before that, and 9 gear at 50, may hold the rest of the hill. You'll be fine.
    Dan.S and MysticHZ Thank this.
  3. C.S.T
    Nov 15, 2017
    149
    Thanks Received:
    65
    So you downshift before you go uphill?
  4. shogun
    shogun Road Train Member
    Jan 23, 2009
    6,075
    Thanks Received:
    72,159
    Doing a regen
    Going uphill you need to downshift when approaching 1100-1200 rpms at least. Keep the motor in the power band.
    Dan.S and JReding Thank this.
  5. C.S.T
    Nov 15, 2017
    149
    Thanks Received:
    65
    So when I going uphill going 65 and the rpm drop at 1200 and the speed is declining to 60mph. Do I have to wait till the speed at 45 before I downshift to 9
    Oldironfan Thanks this.
  6. 201
    Apr 16, 2014
    12,321
    Thanks Received:
    25,196
    Not quite, you did years ago with small motors. If your revs are dropping fast, don't wait for the last minute, if you miss that gear, you may have to drop another. You can feel it in the pedal if it's dropping fast.
    Dan.S and C.S.T Thank this.
  7. pmdriver
    pmdriver Road Train Member
    Nov 14, 2017
    2,338
    Thanks Received:
    3,503
    Have the gear needed to complete the maneuver, be it a long hill, a tight turn. On a hill you may get a ways up but are you proficient to shifting in a quick situation. Stopping on a big hill is dangerous nd can be hard to get going again without destroying the clutch and engine.
  8. C.S.T
    Nov 15, 2017
    149
    Thanks Received:
    65
    I pretty fast with downshifting in floating. I'm not sure if dubble clutch is faster than floating
  9. AModelCat
    29,188
    Thanks Received:
    158,955
    You want to keep the RPM up. If you know you'll need to drop a gear or 2, do it before the RPM drops too low. Once you pull the stick into neutral, you have no engine power trying to pull you up the hill and your speed is going to start dropping fast.
  10. Oldironfan
    Oldironfan Road Train Member
    May 22, 2017
    5,777
    Thanks Received:
    5,543
    Never wait until less than 1200. Wind up to 1800 pm hill if needed.
    At least one gear lower than used to climb up, and jakes.
    C.S.T Thanks this.
