First; I'm on my 5th year of cdl driving and for the most part I consider myself a rookie. I've been driving dry van mostly for the last 4 years. This last week I started with a co driving flatbed and have some questions. Split axle trailer. The split axle allows one to carry more weight? If so, why? I don't understand. My tractor and empty trailer weigh 33680 ( full of fuel and a lot of chains and binders etc); with the split axle my total gross still needs to be 80000 correct? (Meaning I can haul 46320 correct?) I say that the jury is still out on my flatbedding; you guys work pretty hard tarping and such. This has got to be a headache when the weather is bad; yes? Let me thank you in advance for any and all answers; I have to check out for awhile.
The only difference in the 80,000 rule, is you can have 40,000 on the trailer axles instead of 34,000, as long as you have the spread back there.
As HogDog say's you are allowed 40k on the spread. is it a fixed spread or slider? The spread needs to be 10' 02". Then they are considered single axle's not a tandem. Some states like Louisiana ,New Mexico & Colorado enforce the 20,000 lb limit per axle limit.After you load and scale your trailer a few times you will figure it out and be good to go from then on. .
@Dye Guardian, if you don't mind, could you show Mr Sane a picture of your rig, tarped load, and explain your axle spacings and weights?
Maximum allowable axle weights in Ontario: Steer - 14,600 lbs (based on equipment ratings, taking the lowest rating between the axle, tires, and rims) Drives - 40,000 lbs Lead Tridem - 53,000 lbs Pup Tandem - 40,000 Now if we want to go into Michigan and use the lift axles on the trailer it becomes: Drives - 32,000 lbs Lead Lift Axle - 18,000 lbs Lead Tridem - 39,000 lbs Pup Tridem - 39,000 lbs Do you really want me to go into axle spacing?
