Flatdeck tips if any ?!
Discussion in 'Experienced Truckers' Advice' started by Robin72, Jan 25, 2014.
  1. Robin72
    Robin72 Bobtail Member
    Jan 25, 2014
    Thanks Received:
    I tarp a Super B daily.... Mostly lumber! Takes me 2 hours... Even with rubber rope all set up at right locations. Any tips to shorten my time? Make it easier... My tarping job looks great when I'm done... But I don't much care about how it looks... Just don't wanna lose my tarps.... And my haul is usually only about 6 to 8 hours
    ( I have a bad back too). Just looking ways to make job easier.... The easier the better! No! Curtain trailers not a option.... Just trying to stick to a job without moving again... I hate moving around... Always a flaw in every job
  2. TwinStickPeterbilt
    TwinStickPeterbilt Heavy Load Member
    Mar 16, 2013
    707
    Thanks Received:
    910
    Cut your tarps to the exact length you need, I did this for aluminum sows since we haul so many. Make sure when you roll your tarp you have it rolled where all you have to do is flop out the sides and bungee her down.
  3. Ken Worth
    Ken Worth Medium Load Member
    Jun 29, 2008
    639
    Thanks Received:
    191
    Great Plains
    I strap over the tarps and bungee in between....it's a tarp, not a flag.
  4. Robin72
    Jan 25, 2014
    Thanks Received:
    I'll try that Mon
  5. dogg478_1902
    dogg478_1902 Light Load Member
    Jul 28, 2013
    70
    Thanks Received:
    21
    Always try to get the guy loading your trailer to place the tarps up top for you. Another option would be to order some light weight tarps yeah they are a bit expensive but they are a real back saver. Also doing as kenworth said will save a little bit of headache but put some plastic edge protectors up on top just as a little extra insurance.
  6. TwinStickPeterbilt
    Mar 16, 2013
    707
    Thanks Received:
    910
    Not sure that straps over the tarp is a good idea. All that lumber cuts your tarps especially where you are putting your edge protectors.
    Robin72 Thanks this.
  7. Ken Worth
    Jun 29, 2008
    639
    Thanks Received:
    191
    Great Plains
    Yeah, you have to use some common sense about what you're tarping, but I haven't had much problem with that and we haul just about everything. The sharp edges of steel are usually what you have to be the most concerned about. I've never had trouble with lumber, but then we might have better quality tarps than some.
  8. Saddletramp1200
    Saddletramp1200 Road Train Member
    Sep 4, 2011
    2,111
    Thanks Received:
    2,836
    Houston Texas,USA
    Almost 25 years ago I tarped a printing press. Had about 4" of ink on it. The wind blew the ink everywhere. About 3 months to be "Ink" free.
  9. skellr
    skellr Road Train Member
    Jul 17, 2011
    8,737
    Thanks Received:
    12,187
    The Village, Portmeirion
    And I thought onions were bad.
  10. TwinStickPeterbilt
    Mar 16, 2013
    707
    Thanks Received:
    910
    We we have good tarps I'm just anal about my equipment..
