Found an exploit in my ELD.
Discussion in 'ELD Forum | Questions, Answers and Reviews' started by Infosaur, Nov 30, 2017.
  1. Infosaur
    Infosaur Road Train Member
    Oct 21, 2008
    3,611
    Thanks Received:
    5,207
    Berks County PA, to NYC (Daily?)
    I won't say what make/model, but you might want to see if this works with whatever you use.
    So my ELD tends to "flash out" pretty frequently. If it loses a signal from one of it's sources, it begins a reacquire process. This, annoyingly, takes several minutes (like when you want to take your :30 break PRECISELY at the top of the hour, and you spend 15 minutes trying to get it to accept the entry)
    So when I went Off Duty last night, I noticed that the ELD had me on line 4 for 20 minutes, because they hadn't synced in that time frame.
    Only line 3 is fixed, all other lines are editable. :evil4:
  2. ZVar
    ZVar Road Train Member
    Sep 10, 2010
    10,911
    Thanks Received:
    23,827
    Flint, MI
    I'm lost. Are you saying the exploit is the ability to edit any line but drive? That's standard on all/most eld's.
  3. Infosaur
    Oct 21, 2008
    3,611
    Thanks Received:
    5,207
    If the ELD puts you on line 4 instead of line 3 you can change it to line 1.
  4. Mark Kling
    Mark Kling Technology Contributor
    Sep 23, 2007
    10,935
    Thanks Received:
    4,216
    Statesville, NC
    All lines except line 3 are editable..
    Frequently Asked Questions (FAQs) - ELD Rule
    Who can edit an electronic logging device (ELD) record?
    PreviousNext
    Both the driver and authorized carrier staff can make limited edits to an ELD record to correct mistakes or add missing information. All edits must include a note (annotation) to explain the reason for the edit. In addition, the driver must confirm (certify) that any carrier edit is accurate, and resubmit the records. If the driver chooses not to re-certify RODs, this is also reflected in the ELD record. The ELD must keep the original, unedited record, along with the edits. Example: a carrier edits a record to switch a period of time from “off-duty” to “on-duty not driving”, with a note that explains “Driver logged training time incorrectly as off-duty”. The edit and annotation are sent to the driver to verify. The edit is not accepted until the driver confirms it and resubmits the RODS.
    Can a user edit or change driving time that has been recorded by an electronic logging device (ELD) to non-driving time?
    PreviousNext
    No. An ELD automatically records all of the time that a CMV is in motion as driving time that cannot be edited or changed to non-driving time.
  5. Cat sdp
    Cat sdp . .
    Apr 8, 2012
    20,942
    Thanks Received:
    72,811
    Orion's Belt
    I don’t have any problems with mine...
