Freightliner Columbia 120 Reservoir Overflow Dumping Coolant
Discussion in 'Trucks [ Eighteen Wheelers ]' started by tallmon, Feb 25, 2016.
  1. tallmon
    tallmon Medium Load Member
    Oct 22, 2014
    657
    Thanks Received:
    320
    I have an 2008 Col 120 with Detroit. It has the plastic reservoir on the radiator. The reservoir has a plastic cap on top and a plastic cap on the side of it with the overflow tube sticking out of it.
    The other night the coolant level dropped below the sensor and stopped the engine. Added a gallon. About 4 hours later, stopped again, added a gallon. In between the temp spikes up to 220 or so but then comes back down pretty quick when he slows down. It was pouring rain and we couldn't see any obvious leak. The mechanic drove it to the shop and on the way their the temp spiked twice but then came down.
    The mechanic has had it all day today - pressure tested at 15 PSI, checked head gasket, checked EGR cooler, idled for hours, bob-tailed for hours, and found NOTHING! Coolant level and temp all steady all day.
    My driver went out and 5 hours later the temp spikes so he slows down a bit and it gets back to normal. Now the coolant is down below the sensor line and he has to add a gallon. He noticed steam coming out of the overflow tube.
    On my KW's I would just replace the pressure cap and solve the problem.
    Does the Detroit Freightliner have a pressure cap, is it the side cap? Any other thoughts what this might be? Flaky thermostat?
  2. Cory wood
    Cory wood Medium Load Member
    Nov 7, 2015
    335
    Thanks Received:
    162
    If it's loosing coolant and spiking on temp I am going to guess its a cracked head or a head gasket, of course try the coolant reservoir cap and thermostAts first, then the exspensive stuff.
  3. baha
    baha Road Train Member
    Jul 25, 2013
    4,137
    Thanks Received:
    2,837
    ga
    Have driver pull oil filler caps and breather to look for milky oil on top surface of them, if none is found a set of thermo. hopefully will fix it?
  4. tallmon
    Oct 22, 2014
    657
    Thanks Received:
    320
    Oil checked and looks good. Mechanic did the head test and the colors showed ok.
    Is the side cap the pressure cap?
    baha Thanks this.
  5. Cory wood
    Nov 7, 2015
    335
    Thanks Received:
    162
    Did what head tests? Compression into coolant may not be shown if the cooling system is only pressured to 15 when the compression will be much higher.
  6. tallmon
    Oct 22, 2014
    657
    Thanks Received:
    320
    It has two caps, see picture attached. One on top, and one on the side middle that has the overflow tube out of it (middle of picture, left side). Is that the pressure relief cap? (On my KW's it's a metal cap)
  7. AModelCat
    29,390
    Thanks Received:
    161,302
    Did the mechanic run a combustion gas test?
  8. Cruisin thru
    Cruisin thru Bobtail Member
    Feb 20, 2016
    41
    Thanks Received:
    26
    Utah
    Exactly. To rule out the exhaust gas in coolant I hope he at least did this. Other thing is maybe air in system causes this.....possible to have a bleed off screw around thermostat. Slipping belt on water pump or intermittant use. Does it have its own belt for water pump. Radiator pressue cap may rise at hot temp....always have an extra.
  9. tallmon
    Oct 22, 2014
    657
    Thanks Received:
    320
    Yes, I believe he did.
  10. tallmon
    Oct 22, 2014
    657
    Thanks Received:
    320
    Welp, gonna put on a new cap in the morning and see what happens. I hate problems like this because it's not black and white... Thanks for the ideas.
