Front end bouncing
Discussion in 'Questions From New Drivers' started by DirtyBrown, Apr 14, 2016.
  1. DirtyBrown
    DirtyBrown Bobtail Member
    Dec 1, 2015
    48
    Thanks Received:
    14
    Middle Georgia
    Hey guys,
    Got a columbia daycab and when i'm going down the road loaded the front end seems to want to bounce a little bit. however, when i'm empty its fine. Could this be because of the position of the 5th wheel? or could it be I need new drive tires and an alignment?
    Thanks
  2. MUNY
    MUNY Bobtail Member
    Mar 24, 2016
    6
    Thanks Received:
    You need to do balance....thet's all.......
  3. DirtyBrown
    Dec 1, 2015
    48
    Thanks Received:
    14
    Middle Georgia
    balance what?
  4. Lepton1
    Lepton1 Road Train Member
    Nov 23, 2012
    12,647
    Thanks Received:
    25,588
    Yukon, OK
    If you have room weight wise to move the 5th wheel, move it back. See if that alleviates the problem. When I pulled a dry van I hated to have to move the 5th wheel all the way forward to balance a load. It creates a lurching effect on roads with joints or uneven surfaces (think I-5 in LA).
  5. DirtyBrown
    Dec 1, 2015
    48
    Thanks Received:
    14
    Middle Georgia
    it is moved back to the back, so it couldn't be a problem with tires or alignment?
  6. Moosetek13
    Moosetek13 Road Train Member
    Nov 1, 2010
    14,698
    Thanks Received:
    18,481
    Burnsville, MN
    It could be tire balance, alignment, worn shocks, a leveling valve... any number of things.
    The front end of my Volvo shook ever since I first got it. It was new.
    At first it was very light, then over time it got worse.
    The shop wouldn't do anything until the steers showed abnormal wear, then they just replaced the tires.
    The second time they fixed the leveling valve, which took care of the shake for several thousand miles. But it came back.
    The last time they changed the steers and did an alignment. The problem has not returned.in probably 50k miles.
    Lepton1 Thanks this.
  7. DirtyBrown
    Dec 1, 2015
    48
    Thanks Received:
    14
    Middle Georgia
    Thanks, yeah both of my steer tires are wearing pretty good on the inside
  8. Lepton1
    Nov 23, 2012
    12,647
    Thanks Received:
    25,588
    Yukon, OK
    Wow. Is there a particular speed where the bouncing starts or gets really bad?
  9. Lepton1
    Nov 23, 2012
    12,647
    Thanks Received:
    25,588
    Yukon, OK
    Follow the solution from Moosetek. Sounds like balancing and three axle alignment is in order.
  10. DirtyBrown
    Dec 1, 2015
    48
    Thanks Received:
    14
    Middle Georgia
    Just cruising at 70 mph on the interstate?
