Front engine mount d12 2005 vnl 670
Discussion in 'Volvo Forum' started by 05vnl670, Jun 8, 2014.
  1. 05vnl670
    05vnl670 Light Load Member
    Feb 17, 2013
    165
    Thanks Received:
    60
    Has any one replaced the front engine mount under radiator fan? Waht is the easy way to do it? I know oil pan is plastic so how you jack up the engine or how to lift it up. I was looking for repair manualhow to do but i cant find it. Thanks.
  2. OldHasBeen
    OldHasBeen Road Train Member
    Dec 16, 2010
    1,269
    Thanks Received:
    924
    Plastic oil pans???? Really!
    I hope they don't start making plastic pistons, rings, inserts, bearings, heads, & exhaust pipes.
  3. wedge542
    wedge542 Light Load Member
    Aug 13, 2007
    241
    Thanks Received:
    31
    roll tide
    looking s8 up at the front pan bolts you can put a 2x4 on the bolts and jack up the board on the pan bolts, only need to get 2-3", are you replacing as a kit- mounts/bolts/nuts/washers/spacers., if not look at the threads real close for wear from being loose.
  4. 05vnl670
    Feb 17, 2013
    165
    Thanks Received:
    60
    I never knew there was a kit i bought only mount.
  5. nasriza
    nasriza Road Train Member
    Feb 1, 2013
    2,397
    Thanks Received:
    2,070
    Chicago, IL
    I've changed a #### ton of these and I really don't understand how a 2x4 is going to support the engine or better yet what happens when it breaks the K my way I have done it is you have to remove radiator even if u do lift engine no way to remove the mount I've always lift the engine with a forklift from the front metal leg on the sides of the mount
  6. 05vnl670
    Feb 17, 2013
    165
    Thanks Received:
    60
    I tought about removing the crossmember, and removing the mount from bottom , i know i have to suport the engine but i stupid that engine dont have any thing on top to tie chain to it and lift.
  7. nasriza
    Feb 1, 2013
    2,397
    Thanks Received:
    2,070
    Chicago, IL
    Tie it around the fan clutch have done it before and it holds just fine only try to keep it closer to the block side and not fan side and the bottom cross member is a batch to take off since the frame opens up I wouldn't suggest it radiator easiest way to go by far have it done in couple of hours tops
  8. 05vnl670
    Feb 17, 2013
    165
    Thanks Received:
    60
    You would sugest removing radiator only or with intercooler and other parts, i think i have to do this job togeter with water pump, i just need to see i if i need the pump or only gaskets, i have oil leaking from water pump at the junction to engine timing cover.
