Fuel its dark, filters very dirty....whats the problem?
Discussion in 'Questions From New Drivers' started by Neghinam1, Jul 3, 2015.
  1. Neghinam1
    Neghinam1 Bobtail Member
    Nov 2, 2014
    19
    Thanks Received:
    Guys iam new owner operator and esterday I tried to change oil and found that my fuel filter is very dirty and fuel by it self too, it's kind dark, does somebody knows what can be the problem? Here is a photo of my fuel filter. Thank you
  2. Oldman49
    Oldman49 Medium Load Member
    Jul 20, 2014
    353
    Thanks Received:
    300
    Looks like fuel algae. Black slimy algae growing in your fuel tank/system. I am not an expert at all, but have heard the best way is to boil and rinse and dry the tanks and lines. Good luck.
    Neghinam1 Thanks this.
  3. Oldman49
    Jul 20, 2014
    353
    Thanks Received:
    300
    Go to the search window in the upper right corner,type in " fuel algae "..lots of info.
  4. Mr.X
    Mr.X Heavy Load Member
    Oct 31, 2013
    737
    Thanks Received:
    596
    Spokane, WA
    A lot of guys used to dump the old crank case oil into the fuel tanks after an oil change, any possibility the old owner did that?
  5. taxihacker66
    taxihacker66 Road Train Member
    Feb 26, 2012
    1,344
    Thanks Received:
    1,224
    Concrete jungle.
    Never heard of dumping your used oil in the fuel tanks what would be the reason for doing that?…........ I would do what the OLDMAN suggest and add a additve to your fuel tanks. That's what I did just can't remember the name of the stuff i used to remove the. algie .
  6. BoxCarKidd
    BoxCarKidd Road Train Member
    Aug 26, 2014
    4,469
    Thanks Received:
    6,504
    Did your parents live through the great depression? Waste not want not. A gallon to each tank every fill up saves you about $7 and cost about $2,000 in electronic injectors next year. Kileem? Carry extra filters, read the posts.
  7. taxihacker66
    Feb 26, 2012
    1,344
    Thanks Received:
    1,224
    Concrete jungle.
    Yes it was kileem ...worked great.
  8. Mr.X
    Oct 31, 2013
    737
    Thanks Received:
    596
    Spokane, WA
    Simply stating a fact!
    BoxCarKidd and Neghinam1 Thank this.
  9. radioshark
    radioshark Road Train Member
    Nov 19, 2012
    4,573
    Thanks Received:
    22,557
    Go to a marine supply store and get a fuel algecide. They Use It A Lot In boats. That should kill it but carry extra furl filter as the dead algae will clog your fuel filter.
  10. HardlyWorkingNeverHome
    HardlyWorkingNeverHome Heavy Load Member
    Mar 18, 2008
    709
    Thanks Received:
    316
    Hamden,CT
    If it's a cummins 2009-2013 that is soot and or oil but mainly soot. Those engines are real dirty. Won't hurt anything. Just plugs up the fuel filter a little sooner. If you are wanting to be sure, take a sample of the fuel from the filter and send it out to the lab OPS has a relationship with. They can tell you what is in the fuel.
