there is no power going to alot of the fuses panel....no power to windows....volvo power link or vehicle ecu....or radio whats the deal????
Ignition switch. Power feed to the fuse panel. Aren't there 3 posts that spit the power feed in the panel. 1 post is power all the time. 1 post is accessories. 1 post is power only with key on. Check your battery feed for corrosion or broken wires. Good luck. I have the worst time finding electronic gremlins.
Hi Tina your issue sounds like it needs to be dealt with right away,should'nt you be asking the companie's shop that question or a driver wherever you're at?
