Galaxy dx33mhl doesn't recieve
Discussion in 'CB Radio Forum' started by jcross, Jul 28, 2010.
  1. jcross
    jcross Bobtail Member
    Mar 5, 2008
    24
    Thanks Received:
    Kingsland, TX
    I have a Galaxy dx33hml that came with the my truck (Freightliner FL70, yes, I know) when I bought it.
    I can talk but I don't seem to be able to recieve (or at least I can't hear it if I am). I'm not sure about the echo knob or the one next to it (one is echo effect and the other is echo sound (according to the manual)).
    Anyway, when you key the mic the SWR goes right to the number seven on the green on the meter and the led light shows red. I'm not too up on the how to's of CB's. I have the squelch to the left, volume to the middle, RF to the right, RF power switch to hi, Band switch to hi, the Band selector knob is in the middle and the Mode switch to FM.
    I'm not a CB person so, I have no idea whether these settings are right. I have one CB antannae mounted on the passenger side mirror. It is the kind with a coil around the bottom.
    Thoughts or suggestions?
    Thanks in advance.....
  2. josh.c
    josh.c Road Train Member
    Feb 22, 2009
    1,105
    Thanks Received:
    420
    Knoxville, Tn
    There may be another issue, but that switch should be on AM. I don't remember how the band switches work, but you should avoid keying up on it until you know for sure you're on the CB frequencies.
    jcross Thanks this.
  3. Coonass
    Coonass "Freshy Fresh"
    Sep 23, 2008
    1,080
    Thanks Received:
    1,179
    For starters the "mode" switch needs to be on AM and then the "Band" knob needs
    to be on "D".
    Otherwise your who knows where up in the airwaves...:biggrin_2559:
    jcross Thanks this.
  4. WA4GCH
    WA4GCH Road Train Member
    Aug 12, 2009
    3,324
    Thanks Received:
    577
    Seminole Florida
    This is a channel chart you want CB ( band sel D, band sw HI ) all others are ILLEGAL and band sel F band switch puts you in tha 10 meter HAM BAND a place you don't want to be.
    [FONT=Arial, Helvetica, sans-serif][/FONT]
    [FONT=Arial, Helvetica, sans-serif][/FONT]​
    More info ......
    http://www.cbtricks.com/radios/galaxy/dx33hml/index.htm
    Now FM is ILLEGAL don't even go there ...... so make shure it is on AM ....
    jcross Thanks this.
