Getting used to a day cab
Discussion in 'Experienced Truckers' Advice' started by postmandav, May 15, 2013.
  1. postmandav
    postmandav Medium Load Member
    May 18, 2008
    313
    Thanks Received:
    90
    south portland, maine
    I have just recently started a new job as a local driver. I have driven for Werner for 4 years total (2 different times). I have driven Centurys, Classics, 387s, Columbias, and a couple others that i can not remember. Now that I have gone to a much smaller truck, I am having trouble backing. I am used to backing a truck that is much larger. The techniques for driving a much larger truck are the same, but sometimes over wheeling the tractor is causing problems. Go from a Peterbilt 387 to a Freightliner Cascadia day cab and tell me how much fun it is to back a trailer in somewhere. I look like a rookie all over again. How long does it take to really get used to driving a day cab?
  2. CenutryClass
    CenutryClass Road Train Member
    Feb 15, 2006
    1,539
    Thanks Received:
    859
    shouldnt, take much especially if you have been driving that long.
  3. tinytim
    tinytim Road Train Member
    Oct 29, 2007
    5,143
    Thanks Received:
    18,756
    Northern Ontario
    All that extra room to play with and the back window can sure make things tough.
    It'll come to you quick enough. Beats adjusting to a larger truck I imagine.
    Btw, enjoy the local job.
  4. Allow Me.
    May 28, 2009
    10,724
    Thanks Received:
    12,417
    Rancho Mirage, Ca.
    Day cabs are easy. Since you got a local job, can you come early/stay late and practice at your yard ? Are you pulling a pup ? Is this day cab a twin screw ?
  5. postmandav
    May 18, 2008
    313
    Thanks Received:
    90
    twin screw Cascadias
  6. postmandav
    May 18, 2008
    313
    Thanks Received:
    90
    I am used to backing up and turning the wheel and waiting for a few seconds for the trailer to respond. With these daycabs the trailer responds almost immediately. It is just going to take some time. Using the rear window is also something new, because in the sleeper I could never see how close the nose of the trailer was getting to the back of the cab. Time, that is what I need. In a few more weeks I think everything will be a lot easier.
  7. formertaxidriver
    formertaxidriver Heavy Load Member
    Jan 22, 2008
    767
    Thanks Received:
    375
    Aiea, HI
    Try a daycab with a 20' container. The difference between a 1976 Eldorado and a Miata. I was very embarrassed the first time I tried.
  8. DirtyBob
    DirtyBob Road Train Member
    Sep 2, 2010
    1,913
    Thanks Received:
    1,628
    Indiana
    You'll get used to it. Mainly you have to relearn your setups. You're probably setting up with the same timing you used in a bigger truck. You generally have to start later with a daycab because everything will turn and straighten back out faster during your setup. Both times I've gone from OTR to local it took me a week or two before it felt natural again.
  9. Hammer166
    Aug 18, 2007
    7,553
    Thanks Received:
    27,498
    ~8600+' and loving it!
    I'm wondering if you're oversteering. You don't have to use all the available wheel cut. Just asking as this is one of the most common mistakes I see in backing technique.
    CenutryClass and Logan76 Thank this.
  10. Blind Driver
    Blind Driver Road Train Member
    Aug 7, 2006
    3,081
    Thanks Received:
    1,406
    New Albany, IN
    Enjoy your new found turning radius, rear window, and the ability to blind side back easier.
