Got Optimized idle werner??? Come in
Discussion in 'Questions From New Drivers' started by maxter, May 21, 2014.
  1. maxter
    maxter Bobtail Member
    Mar 9, 2014
    41
    Thanks Received:
    11
    So the give me a peterbilt 387 something like that with no apu no Optimize idle no nothin yestwrday I far sleep with 79 80 in the bunker bu not today I got my personal Optimized idle from ta truck stop what do u think guy .... ??? uploadfromtaptalk1400725122265.jpg
    CargoWahgo and tucker Thank this.
  2. Chip Off The Old Block
    Chip Off The Old Block Bobtail Member
    May 21, 2014
    38
    Thanks Received:
    27
    Wooster, Ohio
    That's called problem solving.
  3. Richter
    Richter Road Train Member
    Feb 13, 2012
    4,090
    Thanks Received:
    1,700
    Philadelphia Pa
    normally the optimized idle can be overridden by fooling the temp sensor. Replacing it with the right resister will make it think its cold and allow you to run the motor. Another trick i put a heating pad on it plugged into your inverter. (like the kind you use for your back) If its hot enough it should allow you to idle.
  4. kf4omc
    kf4omc Medium Load Member
    Aug 24, 2012
    330
    Thanks Received:
    181
    Clearwater, FL
    Werner trucks are set with idle if it is warmer than 75 or colder than 20. For that Peterbilt just set breaks. Let idle till engine light flashes. Press any pedal and the light will turn off and engine will idle as long as outside temp stays above 75.
    maxter Thanks this.
  5. CargoWahgo
    CargoWahgo Road Train Member
    Jan 10, 2012
    3,912
    Thanks Received:
    3,945
    Louisville, Kentucky
    Well done.
    Make them ppl pay for the inconvenience!
    Well done.
  6. maxter
    Mar 9, 2014
    41
    Thanks Received:
    11
    Well I have bad news thebtruck still shut off
  7. maxter
    Mar 9, 2014
    41
    Thanks Received:
    11
    U know Where isnthe temp sensor ?
  8. maxter
    Mar 9, 2014
    41
    Thanks Received:
    11
    My truck doesnt not stay on even reaching 90 outside
  9. n3ss
    n3ss Heavy Load Member
    Nov 4, 2013
    737
    Thanks Received:
    340
    Have you tried setting the cruise control while idling? that worked on prime's freightliners. Could be worth a shot.
  10. maxter
    Mar 9, 2014
    41
    Thanks Received:
    11
    I already try that
