Guess its time for an overhead to be done on my C-16!!!
Discussion in 'Kenworth Forum' started by Whitey14243, Sep 3, 2013.
  1. Whitey14243
    Whitey14243 Medium Load Member
    Aug 12, 2010
    359
    Thanks Received:
    97
    Moreland, GA
    Recently purchased a 2000 W900L with a C-16 600HP. I bought it back in April 2013 and just recently leased it onto a company. I'm on my 3rd run with the truck and now I'm seeing green tint in my fresh oil. I took the truck to TA to get it serviced right before I hit the road and had Rotella oil with a gallon of Lucas put in it with Caterpillar filters and truck is also equipped with a Gulf-Coast Oil Bypass system so I had those 2 filters changed as well. The old oil that was in the truck was completely black. According to the sticker on windshield the oil had about 20K+ miles on it and I don't even know what kind of oil he had in here. So I checked my oil the other day and started seeing a greenish tint on areas of my dipstick.. Wiped it off and checked oil again and same thing. So I'm trying to determine if its diesel or coolant. Iv tried smelling it but it doesn't really smell, just smells like used motor oil from a diesel. So ill be delivering my last stop tomorrow in Laredo, TX. Thinking about finding a Caterpillar Shop down there and seeing what they say. Will probably end up having the overhead dun on the truck. Any other suggestions on what may be the greenish tint??
  2. truckmechanic
    truckmechanic Medium Load Member
    Jan 14, 2012
    534
    Thanks Received:
    140
    Hi Desert Ca
    Get an oil sample done that will tell you everything you need to know
  3. Ezrider_48501
    Apr 2, 2011
    3,845
    Thanks Received:
    5,130
    bismarck, nd
    cant really tell anything from that pic. if it was coolant your oil would be gray. only way to know what if anything is going on you should have a oil sample done. running the rack shouldn't have a effect one way or the other on the oil.
  4. baha
    baha Road Train Member
    Jul 25, 2013
    4,137
    Thanks Received:
    2,836
    ga
    GULF co. filters has a sample U can use he will tell
  5. Whitey14243
    Aug 12, 2010
    359
    Thanks Received:
    97
    Moreland, GA
    This is the 1st truck iv owned so still new on where the best places to get certain things done. Was thinking about going to a SpeedCo for oil sample but figured I would probably be better off just letting CAT do the oil sample. Any ideas on that??
  6. king Q
    king Q Road Train Member
    Jul 26, 2010
    2,880
    Thanks Received:
    3,032
    Johannesburg sa
    That oil looks very clean for oil that is even 1000 miles old.
    What concerns me is not so much the green (no idea what it is) but what appears to be diesel dilution.
    Oil is blacker then that usually.
    A way we used to check for this was to drip a drop of oil on a napkin or piece of newspaper.
    If it just made a black drop it was generally okay.
    If the black drop got surrounded by a more transparent wet mark like the color I see in your photo it was usually diesel in the oil as it separates and spreads differently.
    As stated have an oil sample done.
    Whitey14243 Thanks this.
  7. TruckerPete1990
    TruckerPete1990 Road Train Member
    Jul 16, 2012
    8,623
    Thanks Received:
    5,377
    Bentonville Arkansas
    20k on oil isn't that bad some go to 25k google oil sample no need to change ur oil every 15 k miles
  8. spyder7723
    spyder7723 Road Train Member
    Mar 31, 2013
    15,470
    Thanks Received:
    25,061
    sarasota, fl
    don't use speedco for an oil sample, they don't have the training and don't follow proper lab protocols. go to cat for one, or call up one of the oil analysis companies, you can ship them your sample, a bit of a pain, but the best way.
  9. popcorn169
    popcorn169 Road Train Member
    Sep 5, 2011
    2,194
    Thanks Received:
    1,714
    state of confusion
    If you follow Kevin Rutherfords advice then Polaris Labs is a good one to use. They will email you the results and if you have any questions you can call them. You can google them and it will give you the info you need.
  10. DieselDog81
    DieselDog81 Medium Load Member
    Apr 7, 2012
    415
    Thanks Received:
    213
    Between here and there
    The green tint could be from the additive that you put in the oil. Just a question, but why are you putting an additive into the oil? What are you looking to control/change/improve with the additive?
    Semi Crazy and 123456 Thank this.
