have a rd test for a job but still have some concerns on shifting
Discussion in 'Questions From New Drivers' started by carlos715, Mar 15, 2012.
  1. carlos715
    carlos715 Bobtail Member
    Mar 15, 2012
    8
    Thanks Received:
    western mass
    i have trouble on finding the right gear when i suddenly have to slow down like if im in 9th gear and my speeed goes down to 15 and rpm around 9 how much fuel should i give it to skip gears whe the rpm are that low
  2. MNoutkast
    MNoutkast Medium Load Member
    Feb 24, 2012
    441
    Thanks Received:
    151
    Elk River, MN
    Usually just a light tap is all it takes, especially if you are low in the RPM's.
    carlos715 Thanks this.
  3. carlos715
    Mar 15, 2012
    8
    Thanks Received:
    western mass
    usually i bring it up to 12 and it grinds should i do a litlle less
  4. flatbed60
    flatbed60 Bobtail Member
    Oct 24, 2011
    30
    Thanks Received:
    If it wont go in, go up a gear .
    Peace
  5. GasHauler
    Oct 23, 2005
    6,257
    Thanks Received:
    4,365
    Vegas/Jersey
    I just give it a little tap. Of course no one can tell you for sure how much to bring the engine up since all trucks are different. Just relax and be safe during your road test. They know drivers miss gears once in awhile and safety is your key.
    carlos715 and lonewolf4ad Thank this.
  6. carlos715
    Mar 15, 2012
    8
    Thanks Received:
    western mass
    ok thanks safety is first
  7. Peterbeatinit
    Peterbeatinit Medium Load Member
    Mar 8, 2012
    340
    Thanks Received:
    120
    San Antonio Tx
    usually a bump of 300 to 400 rpm is enough..depending on ground speed..it could be your ground speed is too slow for the gear you are selecting..
    see others posts..up or down if you are empty and brake..you can skip a gear on the way down..which would require a bit higher bump depending on ground speed.
    If you are just out of school and are due to go out with a trainer they probably wo't say too much o the gear shifting..its an acquired skill. If you have been out with a trainer already and are still having problems with down shifting, tell them you need another week with trainer before you feel you will be ready..and drive that week..as much as possible..and run the gears as much as possible to get the timing down..
    Again..shifting one of these is all about timing..rush a shift and you will grid the gears..most people down shifting are rushing their shift or are too aggressive on their rpm bump..
    Deep breath, relax, clutch to neutral, bump, clutch to gear
    Petey
  8. carlos715
    Mar 15, 2012
    8
    Thanks Received:
    western mass
    ok just wanna make sure same question but if im in a faster speed and rpm around 11 9th wanting to ski to 6th i would have to rev it up around 20rpm iam i right
  9. carlos715
    Mar 15, 2012
    8
    Thanks Received:
    western mass
    Peterbeatinit thanks it was very helpful
  10. Peterbeatinit
    Mar 8, 2012
    340
    Thanks Received:
    120
    San Antonio Tx
    you wouldn't ever skip 9th to sixth..9th to seventh maybe..but you would have to be way slower than speeds in 8th gear..
    Yeah..you would still bump it a bit higher than 8th...
    This might help you too..
    When you shift up..watch the tach and see what the rpm drops to..usually about 900 rpm or so..
    so when you are slowing down..wait to down shift till you hit 900 rpm..bump to 1500 which is usually when you upshift..as the tach starts to fall back off..clutch and apply light pressure in the direction of the gear you want to go in to..the gear shift will move and kind of pause..you'll feel it..when the rpms match between engine and trans just right..that light pressure will disappear and it will almost be like the gear shift is moving on its own..don't force it in..she'll go in when she's ready...if it doesn't..bump again and go next lower...apply a bit more pressure..
    If you are trying to force it..of course its going to grind...the trans isn't ready..I would teach my students..pointer finger and thumb only on the gear shift..on my 13 speed I had at the time there was a definite pause in the throw of the shifter they would feel while they had the clutch in waiting on rpms to fall to that magic spot..then it would go in like a hit knife through butter..It does't take a lot of force..a lot of times when they ground the gears they were trying to force the trans into gear..big no no..slow down..just use finger and thumb on the shifter..you'll feel that magic spot..it will pop in when rpms match
    Petey
